Playback issue
Server Version#: 4.130.0
Player Version#: 10.14.0.541
Hello there.
I’m on an Android 10 tablet supporting H264 baseline L4.1.
It fails to play the following file, although it’s H264 baseline L4.1:
Complete name                            : \\SERVER\Media Sample.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 2.47 GiB
Duration                                 : 49 min 10 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 7 184 kb/s
Frame rate                               : 23.976 FPS
Encoded date                             : 2024-05-23 12:41:01 UTC
Writing application                      : HandBrake 1.8.0 2024052000
Writing library                          : Lavf61.1.100
ErrorDetectionType                       : Per level 1
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Constrained Baseline@L4.1
Format settings                          : 4 Ref Frames
Format settings, CABAC                   : No
Format settings, Reference frames        : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Writing library                          : x264 core 164 r3186 585e0199
Encoding settings                        : cabac=0 / ref=4 / deblock=1:-3:-3 / analyse=0x1:0x131 / me=umh / subme=10 / psy=1 / psy_rd=2.00:0.70 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=62500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.20
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : A_TRUEHD
Duration                                 : 49 min 6 s
Bit rate mode                            : Variable
Maximum bit rate                         : 7 701 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Compression mode                         : Lossless
Title                                    : Surround 7.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 11
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
mixlevel                                 : 80 dB
ltrtcmixlev                              : 3.0 dB
ltrtsurmixlev                            : 3.0 dB
lorocmixlev                              : 3.0 dB
lorosurmixlev                            : 3.0 dB
Of course the same happens with same specs other media, but I’m sure this worked in the past.
Device is set with no pass-through and original quality, with no data limitation.
Server has video transcoding disabled (never needed), no idea about audio transcoding cause I could find no settings, but I saw it transcoding to Opus with Plexamp.
Attaching client and server logs.
com.plexapp.android 2024-05-24 10-30.log (212.6 KB)
Plex Media Server.log (1.8 MB)
Any suggestions?
Regars
