Server Version#: 1.24.4.5081 (Linux)
Player Version#: Mostly web player (but also LG smart TV 5.25.2 and PS5 latest)
Plex Pass subscriber
Hi!
I’m having issues when using the Watch Together feature with my friend that lives far away. If we don’t use the Watch Together option, and play the wanted content individually at the same time, playback happens smoothly without any stutter or rewinding.
But when we use the Watch Together option, playback initially takes a lot to buffer for my friend, then when it starts playing, it rewinds back every 2-5 seconds and gets stuck in a loop for some minutes till it moves forward some more seconds and the loop occurs again. If my friend leaves, it starts to play smoothly for me. But ironically, even if I’m the one who leaves, it starts to play smoothly and without interruptions for my friend, who’s watching remotely.
A month ago, the feature worked relatively flawlessly, even on my LG smart TV (webOS 3.4), which is my primary player. In the recent weeks, the feature hasn’t worked at all on my LG TV. Whenever I click on “Watch Together” for some content, it shows me the message “Unable to send invite. Please try again.” . Although I can see the newly created “Watch Together” room in the home screen, I can’t join it, it just shows “Could not join at this time” when I try. This whole process worked a month ago in my LG TV, as I mentioned earlier.
Because it didn’t work on my primary player, I was forced to use the feature on other players, a web browser (Edge Chromium) and on PlayStation 5. While the initial process of creating a Watch Together room worked there, and sometimes even the playback worked somewhat acceptably, recently I get constant loops (which I described above) that make content unwatchable.
I’ve tried a multitude of adjustments and setting changes. I’ve changed quality, player and transcoder settings.
Seeing some suggestions, I’ve even optimized the video files from 1080p to 720p so that my friend would remote stream the 720p file directly without transcoding. That actually fixed for a while but then the same issues started occuring again.
I collected some logs yesterday but unfortunately they’re verbose ones. I only realized now that I should’ve chosen normal debug logs.
I could have forgotten to mention some detail, so feel free to ask me.
Thanks in advance for your help!
