Playback mpegts
Been doing some tests but haven’t been able to get a mpegts file playing correctly. Audio is fine but i can’t get video to work.
Playing the file in xbmc or vlc works just fine. End result should be http streaming of mpegts for an eyetv plugin. Is it possible
to get this to work?
*** General Parameters ***<br />
- Name:  vlc-output.ts <br />
- Container:  Mpeg Transport Stream <br />
- Size:  50,75 MB <br />
- Duration:  1mn 2s <br />
- Bitrate:  6 437 Kbps <br />
<br />
*** Video Track Parameters ***<br />
- Format:  H.264/MPEG-4 AVC <br />
- Bitrate:  Max.: Undefined / Average: 5 343 Kbps / Min.: Undefined <br />
- Frame rate (fps):  Max.: Undefined / Average: 25.000 / Min.: Undefined <br />
- Encoding profile:  Main@L4.0 <br />
- Image size:  1920*1080 <br />
- Pixel Aspect Ratio:  Undefined <br />
- Display Aspect Ratio:  16:9 <br />
- Interlacing:  Interlaced - Top Field First <br />
<br />
*** First Audio Track Parameters ***<br />
- Format:  AC3-A52 <br />
- Bitrate:  384 Kbps <br />
- Resolution:  16 bits <br />
- Rate:  48.0 KHz <br />
- Channel(s):  2 (stereo) <br />
- Position:  Front: L C R, Side: L R, LFE <br />
<br />
*** Miscellaneous ***<br />
- Subtitle(s): #1 : DVB Subtitle - Dutch / <br />
- Album: Undefined<br />
- Performer: Undefined<br />
- Genre: Undefined<br />
- Encoded date: Undefined<br />
- Album artist: Undefined
20:37:03 T:2886976192 M:5976018944  NOTICE: DVDPlayer: Opening: /Users/Aequitas/Documents/vlc-output.ts<br />
20:37:03 T:2886976192 M:5976018944 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED<br />
20:37:03 T:2959175680 M:5976010752  NOTICE: Creating InputStream<br />
20:37:03 T:2959175680 M:5975953408  NOTICE: Creating Demuxer<br />
20:37:03 T:2959175680 M:5952434176  NOTICE: Aggregate bitrate = 768000, file bitrate = 6281186.<br />
20:37:03 T:2959175680 M:5952434176  NOTICE: Setting cache size to 3833KB (bitrate of 6281186, numSeconds = 5)<br />
20:37:03 T:2959175680 M:5952434176  NOTICE: Opening video stream: 0 source: 256<br />
20:37:03 T:2959175680 M:5952434176  NOTICE: Creating video codec with codec id: 28<br />
20:37:03 T:2959175680 M:5952233472  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10<br />
20:37:03 T:2959175680 M:5952192512  NOTICE: Creating video thread<br />
20:37:03 T:2959175680 M:5952184320  NOTICE: Opening audio stream: 1 source: 256<br />
20:37:03 T:2959175680 M:5952184320  NOTICE: Finding audio codec for: 86019<br />
20:37:03 T:2959175680 M:5951893504  NOTICE: Creating audio thread<br />
20:37:03 T:2965032960 M:5951885312  NOTICE: running thread: CDVDPlayerAudio::Process()<br />
20:37:03 T:2965032960 M:5951496192  NOTICE: Creating audio device with codec id: 86019, channels: 6, sample rate: 48000, no pass-through<br />
20:37:03 T:2964500480 M:5946982400  NOTICE: running thread: video_thread<br />
20:37:07 T:2964500480 M:5873614848 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available<br />
20:37:09 T:2886976192 M:5872758784 WARNING: Previous line repeats 17 times.<br />
20:37:09 T:2886976192 M:5872758784  NOTICE: CDVDPlayer::CloseFile()<br />
20:37:09 T:2964500480 M:5872758784 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available<br />
20:37:09 T:2886976192 M:5872758784  NOTICE: DVDPlayer: waiting for threads to exit
Is it possible the Laika client still doesn’t support http live streaming with ffmpeg? Just reran the test through PMS with PleXBMC and the live streaming of mpegts works like a treat, still a bit slow but it does full quality …
