Server Version#: Version 1.24.5.5173
Player Version#: 5.27.3 (On Samsung 75tu7020)
I have bought a Plex Lifetime pass for the hardware Encoding and the HDR tone mapping.
Unfortunately now my server is unable to provide a stutter free experience on playing HDR media:
Media
- Duration 55:22
- Bitrate 14003 kbps
- Width 3840
- Height 2160
- Aspect Ratio 1.78
- Video Resolution 4K
- Container MKV
- Video Frame Rate 24p
- Video Profile main 10
Part
Duration 55:22
Size 5.42 GB
Container MKV
Codec HEVC
Bitrate 11761 kbps
Language English
Language Tag en
D O V I B L Compat I D 6
D O V I B L Present true
D O V I Level 6
D O V I Present true
D O V I Profile 8
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 2160
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
Level 5.1
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K (HEVC Main 10 HDR)
Extended Display Title 4K (HEVC Main 10 HDR)
Codec EAC3
Channels 6
Bitrate 1023 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Title EAC3 7.1
Display Title English (EAC3 5.1)
Extended Display Title EAC3 7.1 (English 5.1)
Codec AC3
Channels 6
Bitrate 448 kbps
Language English
Language Tag en
Only when I turn off acceleration and hdr tone mapping, it plays smoothly.
I’m using Windows 10, with an i7 8700K at 5ghz, 32gb ram and a Geforce 1080TI.
With software encoding I see my cpu use go to 100%.
With hardware acceleration it only goes up to 60 ish %, with my GPU use hovering around only 5-10%…
Is my hardware insufficient for HDR tone mapping? Would upgrading to an Intel Core i7-9700K help (which I can still do on my platform)?
Also why is the CPU use still so high (~60%) with GPU encoding enabled (which is barely used)?
I see HDR tone mapping is not supported on the gpu on Windows, will this be fixed
I feel like upgrading to Plex lifetime pass is giving me more problems than it has solved/improved…
MY TV should decode HDR10 natively, I don’t really understand why it is being transcoded in the first place?
EDIT:
I think I see a problem, the video is being encoded to a way to high bitrate:
My TV only has a slow 100 mbit LAN port… How can I limit LAN bitrate to this TV at 100 or 95 mbps?
EDIT 2:
my 2nd tv which is on Wifi has the same issue:
Though with a much lower bitrate…
The right side of the graph is the 2017 tv, the left side of the graph is the 2020 tv.
Other HDR media is not being transcoded but directplayed:"
So why does Plex need to transcode the other media?
