Server Version#:v1.42.1.10060
Player Version#:2025.23.0
Whenever I try to open the “Playback Options” menu, the popup immediately disappears. I have to tap it multiple times before the “Playback Options” popup menu finally stays open.
Hi, this is a known issue but unfortunately there’s no ETA of when it will be fixed. When you tap on Playback Options, the menu is minimised, so as a workaround you can drag it up to access it.
