Playback randomly pauses on local network, server loosing network interface
Server Version#: 1.19.1.2701
Windows 10
Processor Intel® Core™ i7-8700 CPU @ 3.20GHz
NIC Killer E2400 Gigabit Ethernet Controller
I have latest NIC drivers installed.
I have experienced the last few days playing a show from my plex server running on a windows 10 PC to a NVIDIA shield that the show will just randomly pause playing. If I close the plex client and reopen I can continue playing and it may or may not pause again. The content is being direct played.
I do see in the logs on the server where it appears to be loosing the NIC around the time I have the issue with playback, however, the PC is not actually loosing the NIC, as nothing else on it has any issues an no messages in event log. It just appears to be the plex server having issues.
Apr 26, 2020 12:21:46.526 [19072] DEBUG - Network change. Apr 26, 2020 12:21:46.526 [19072] DEBUG - NetworkInterface: Notified of network changed (force=0) Apr 26, 2020 12:21:46.541 [19072] DEBUG - Detected primary interface: 192.168.50.99 Apr 26, 2020 12:21:46.541 [19072] DEBUG - Network interfaces: Apr 26, 2020 12:21:46.541 [19072] DEBUG - NetworkService: Got notification of changed network (first change: 0) Apr 26, 2020 12:21:46.541 [19072] DEBUG - NetworkService: Dispatch network change after two second delay.
Apr 26, 2020 12:21:46.549 [17224] ERROR - Error issuing curl_easy_perform(handle): 6
Apr 26, 2020 12:21:46.549 [17224] WARN - HTTP error requesting GET http://plex.tv/pms/:/ip (6, Couldn’t resolve host name) (Could not resolve host: plex.tv)
Apr 26, 2020 12:21:46.549 [17224] ERROR - PublicAddressManager: Unable to get public IP adddress from myPlex (httpCode=-6):
Apr 26, 2020 12:21:52.927 [19072] DEBUG - Network change.
Apr 26, 2020 12:21:52.927 [19072] DEBUG - NetworkInterface: Notified of network changed (force=0)
Apr 26, 2020 12:21:52.934 [19072] DEBUG - Detected primary interface: 192.168.50.99
Apr 26, 2020 12:21:52.934 [19072] DEBUG - Network interfaces:
Apr 26, 2020 12:21:52.934 [19072] DEBUG - * 9 Ethernet {3580173C-EDED-4DB5-BBD2-36D4C473D7A2} (192.168.50.99) (loopback: 0)
Apr 26, 2020 12:21:52.934 [19072] DEBUG - NetworkService: Got notification of changed network (first change: 0)
Apr 26, 2020 12:21:52.934 [19072] DEBUG - NetworkService: Dispatch network change after two second delay.
What is causing the plex server application to not be able to see the NIC for a short time?
I am attaching the server log:
Plex Media Server.log (1.2 MB)
