Playback stopped conversion failed the transcoder failed to start
Server Version#: 1.43.0.10492
Player Version#: 8.45 (9684)
It just won’t play anything anymore
Feb 15, 2026 01:20:32.608 [7804] INFO - Plex Media Server v1.43.0.10492-121068a07 - Micro-Star International Co., Ltd. MS-7C95 x64-x64 - build: windows-x86_64 windows - GMT -12:00
Feb 15, 2026 01:20:32.608 [7804] INFO - Windows version: 10.0 (Build 26200), language en-US
Feb 15, 2026 01:20:32.608 [7804] INFO - 12 3800 MHz processor(s): Architecture=9, Level=23, Revision=28928 Processor Identifier=AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
Feb 15, 2026 01:20:32.608 [7804] INFO - Compiler is - MSVC 1929
Feb 15, 2026 01:20:32.955 [32568] WARN - [CERT/OCSP] getCertInfo failed; skipping stapling
Feb 15, 2026 01:20:32.956 [32568] INFO - Running migrations. (EPG 0)
Feb 15, 2026 01:20:32.971 [32568] INFO - Running migrations. (EPG 0)
Feb 15, 2026 01:20:34.424 [35992] INFO - Refreshing paths watched by LibraryUpdateManager
Feb 15, 2026 01:20:34.610 [27536] WARN - Crash: Crash reporting disabled
Feb 15, 2026 01:20:34.620 [30584] WARN - [Req#18] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled ‘unknown’ since we don’t really know the name.
Feb 15, 2026 01:20:34.640 [30584] WARN - [Req#1f] MyPlex: attempted a reachability check but we’re not yet online.
Feb 15, 2026 01:20:34.884 [38716] INFO - [Req#17] AutoUpdate: no updates available
Feb 15, 2026 01:20:35.618 [12904] WARN - MyPlex: attempted a reachability check but we’re not yet online.
Feb 15, 2026 01:20:47.302 [4304] WARN - [Req#6e] QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Feb 15, 2026 01:20:47.302 [4304] WARN - [Req#6e] QueryParser: Invalid field ‘pinnedContentDirectoryID’ found, ignoring.
Feb 15, 2026 01:20:47.306 [4304] WARN - [Req#6e] QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Feb 15, 2026 01:20:47.306 [4304] WARN - [Req#6e] QueryParser: Invalid field ‘pinnedContentDirectoryID’ found, ignoring.
Feb 15, 2026 01:20:51.036 [30584] INFO - [Req#81] AutoUpdate: no updates available
Feb 15, 2026 01:20:53.510 [30584] ERROR - [Req#88] Unknown metadata type: folder
Feb 15, 2026 01:20:57.555 [4304] INFO - [Req#8a] AutoUpdate: no updates available
Feb 15, 2026 01:20:57.784 [30584] ERROR - [Req#90] Unknown metadata type: folder
Feb 15, 2026 01:20:58.632 [4304] ERROR - [Req#91] Unknown metadata type: folder
Feb 15, 2026 01:21:01.878 [4304] ERROR - [Req#aa/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:01.878 [30584] ERROR - [Req#9f/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:01.878 [37496] ERROR - [Req#6f/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:01.879 [16644] ERROR - [Req#82/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:01.880 [28888] ERROR - [Req#71/Transcode/Req#ab/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:01.888 [28888] INFO - [Req#71/Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 15, 2026 01:21:01.923 [28888] ERROR - [Req#ae/Transcode/Req#b2/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.249 [16644] ERROR - [Req#ac/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.272 [16644] ERROR - [Req#bf/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.287 [16644] ERROR - [Req#c4/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.360 [16644] ERROR - [Req#6c/Transcode/Req#d4/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.485 [16644] ERROR - [Req#d1/Transcode/Req#d7/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.607 [37496] ERROR - [Req#dc/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
Feb 15, 2026 01:21:02.614 [37496] ERROR - [Req#d6/Transcode/92C71250-89AD-4EB9-8A66-5EB4F1A47761] Error configuring transcoder: TPU: Failed to download sub-stream to temporary file
Feb 15, 2026 01:21:02.751 [37496] WARN - [Req#de/Transcode] Got a request to stop a transcode session without a valid session GUID.
Feb 15, 2026 01:21:12.843 [16644] INFO - [Req#112] AutoUpdate: no updates available
When I have trailers enabled to play before a movie, almost every time all I get is an error message that the transcoder could not be started. And then I have these messages in my log too.
Same here after I turned off all trailers all the movies started working again. Not sure if this was an issue after an update or not. It just started in Jan so could be new update.
Same issue PMS 1.43.10492…
[Req#422/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘iva’
[Req#425/Transcode/Req#426/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘iva’
[Req#43f/Transcode/Req#451/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
[Req#43f/Transcode] Error configuring transcoder: TPU: Failed to download sub-stream to temporary file
[Req#459/Transcode/Req#45d/MetadataAgentManager/getAgent] Unable to find metadata agent provider for identifier ‘https’
[Req#459/Transcode] Denying access to transcode of key /library/metadata/14084 due to terminated session
Does appear to only be an issues if trailers is enabled.
Correction: Appears to only be related to trailers for movies not in the Library.
Hi there, I have the same issue with plex 1.43.0.10492
Disabling trailers works fine, thank you for this workaround.
