Playback stops randomly
Have a similar if not the same issue.
Running a standalone Plex server (1.21.4.4079) on Ubuntu.
Local files residing on that system work perfectly fine when played via the Samsung TV app.
Once I move those file to my NAS (Unraid share) Plex plays the exact same file for ~28 minutes before “stopping” and showing a black screen. Scrubbing backwards plays fine, but anything past that 28 minute mark will not play. Time varies depending on movie, but generally about 30 min in.
The Unraid share is mounted on my Plex system using CIFS.
*Edit: Small note, I am using /dev/shm for transcoding, but with 16gb total (I believe it defaults to 8gb for the ram disk) it should be more than enough for 1-2 simultaneous 1080p transcodes. Never had an issue with local file playback.
Based on others logs, I suspect it’s something to do with the network streaming from the nas → plex and the transcoding of that network stream. Time out? /tmp issues?
This has been happening for ~9 months?!?! I just recently setup the nas and moved everything over. This is a bit of a showstopper since it seems like fairly standard practice (plex server + non-local file storage).
Anyone have any details on possible resolutions or eta on fix… or even acknowledgement of the issue from devs?
*Edit: Just saw there is an update for the server 1.22.0.4136
Has fix: * (Transcoder) Sessions could become unresponsive after seek requests with certain timings, most commonly seen on Samsung devices (#11703)
Any chance this helps resolve the issue?
Edit 3: No. No it does not resolve the issue.
Same problems (might actually be worse now - some movies fail in the 13-15min range).
So this is… A 2 year old bug now? This is starting to get really obnoxious.
Same bug:
Ubuntu 18.04 server
Client: LG TV webos Plex app
Files local to server
I stopped using Plex back in Aug 2019 and switched to emby due to this issue (as you can see from my previous post)
I have been using Emby daily now since then and haven’t had a single issue to speak of… (too bad the plex devs are incapable of releasing anything so stable)
I just recently decided to build a new server with more storage space (96tb worth of ironwolf pros :wink: and thought I should try out plex again to see if they had finally ironed out this issues after a few years. After all I did pay for a lifetime plex pass that hasent been put to use.
Well after installing the latest version of plex for windows (1.23.0.4497)
Adding my libraries and letting it collect all the metadata (took all day) I installed plex to my android tablet.
I was finally ready to test, I played two episodes of ‘friends’ with no issues, set it up to play som movies and while it does take annoyingly long to load any movie compared to emby it played through a list of four movies today without stopping.
I then went to my music library and attempted to play BfS ‘Emily’ and all I got was “an error occoured while playing this item” weird… I tried to play Ken Ashcorp ‘Absolute Territory’ “an error occoured while playing this item”… in fact i tried about a dozen other random songs and none of them would play. I did some trouble shooting, Added a few songs to a different folder and created another ple. Library. attempted to play them again but kept getting the same error. The last song I attempted to play was Agent Orange ‘The Last Goodbye’. After that I uninstalled plex, installed emby, added my libraries and like magic everything works… I dont know what to say guys plex is still unuseable and buggy.
I am on a Shield TV Pro that I have been using without issue for over a year (ethernet)
I just moved and now need to use the Shield TV Pro over wifi and I am now getting random video freezing. I need to close Plex and open it again to restart content. When connected via ethernet the problem disappears. This is with an Asus 86u router with an excellent connection. Happens with every type of content. When I check my network log this is what I get
18:57:10.579  i: [PlaybackTimeBehaviour] Time: 263215 IsStarted: true
07-07 18:57:10.947  i: [ExoPlayer][EventLogger] loading [eventTime=265.91, mediaPos=1394.61, window=0, period=0, true]
07-07 18:57:10.953  i: [ExoPlayer][EventLogger] loading [eventTime=265.91, mediaPos=1394.61, window=0, period=0, false]
07-07 18:57:11.331  i: [PlaybackTimeBehaviour] Time: 263967 IsStarted: true
07-07 18:57:11.541  i: [ExoPlayer][EventLogger] loading [eventTime=266.50, mediaPos=1395.20, window=0, period=0, true]
07-07 18:57:11.541  i: [ExoPlayer][EventLogger] loading [eventTime=266.50, mediaPos=1395.20, window=0, period=0, false]
07-07 18:57:11.832  i: [PlaybackTimeBehaviour] Time: 264468 IsStarted: true
07-07 18:57:12.247  i: [ExoPlayer][EventLogger] loading [eventTime=267.21, mediaPos=1395.91, window=0, period=0, true]
07-07 18:57:12.251  i: [ExoPlayer][EventLogger] loading [eventTime=267.21, mediaPos=1395.91, window=0, period=0, false]
07-07 18:57:12.586  i: [PlaybackTimeBehaviour] Time: 265220 IsStarted: true
07-07 18:57:13.210  i: [ExoPlayer][EventLogger] loading [eventTime=268.17, mediaPos=1396.87, window=0, period=0, true]
07-07 18:57:13.211  i: [ExoPlayer][EventLogger] loading [eventTime=268.17, mediaPos=1396.87, window=0, period=0, false]
07-07 18:57:13.337  i: [PlaybackTimeBehaviour] Time: 265972 IsStarted: true
07-07 18:57:13.716  i: [ExoPlayer][EventLogger] loading [eventTime=268.68, mediaPos=1397.38, window=0, period=0, true]
07-07 18:57:13.717  i: [ExoPlayer][EventLogger] loading [eventTime=268.68, mediaPos=1397.38, window=0, period=0, false]
07-07 18:57:13.837  i: [PlaybackTimeBehaviour] Time: 266473 IsStarted: true
07-07 18:57:14.211  i: [ExoPlayer][EventLogger] loading [eventTime=269.17, mediaPos=1397.87, window=0, period=0, true]
07-07 18:57:14.213  i: [ExoPlayer][EventLogger] loading [eventTime=269.17, mediaPos=1397.87, window=0, period=0, false]
07-07 18:57:14.588  i: [PlaybackTimeBehaviour] Time: 267224 IsStarted: true
07-07 18:57:15.043  i: [ExoPlayer][EventLogger] loading [eventTime=270.00, mediaPos=1398.70, window=0, period=0, true]
07-07 18:57:15.048  i: [ExoPlayer][EventLogger] loading [eventTime=270.01, mediaPos=1398.70, window=0, period=0, false]
07-07 18:57:15.339  i: [PlaybackTimeBehaviour] Time: 267975 IsStarted: true
07-07 18:57:15.747  i: [ExoPlayer][EventLogger] loading [eventTime=270.71, mediaPos=1399.41, window=0, period=0, true]
07-07 18:57:15.749  i: [ExoPlayer][EventLogger] loading [eventTime=270.71, mediaPos=1399.41, window=0, period=0, false]
07-07 18:57:15.842  i: [PlaybackTimeBehaviour] Time: 268478 IsStarted: true
07-07 18:57:16.083  i: [ExoPlayer][EventLogger] loading [eventTime=271.04, mediaPos=1399.74, window=0, period=0, true]
07-07 18:57:16.087  i: [ExoPlayer][EventLogger] loading [eventTime=271.05, mediaPos=1399.74, window=0, period=0, false]
07-07 18:57:16.591  i: [PlaybackTimeBehaviour] Time: 269226 IsStarted: true
07-07 18:57:16.868  i: [PlaybackTimeBehaviour] Time: 269504 IsStarted: true
07-07 18:57:16.869  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=80440&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=269504&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1400414&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:57:16.877  i: [ExoPlayer][EventLogger] loading [eventTime=271.84, mediaPos=1400.54, window=0, period=0, true]
07-07 18:57:16.880  i: [ExoPlayer][EventLogger] loading [eventTime=271.84, mediaPos=1400.54, window=0, period=0, false]
07-07 18:57:17.342  i: [PlaybackTimeBehaviour] Time: 269977 IsStarted: true
07-07 18:57:17.707  i: [ExoPlayer][EventLogger] loading [eventTime=272.67, mediaPos=1401.38, window=0, period=0, true]
07-07 18:57:17.707  i: [ExoPlayer][EventLogger] loading [eventTime=272.67, mediaPos=1401.38, window=0, period=0, false]
07-07 18:57:17.842  i: [PlaybackTimeBehaviour] Time: 270478 IsStarted: true
07-07 18:57:17.905  i: [ExoPlayer][EventLogger] loading [eventTime=272.87, mediaPos=1401.57, window=0, period=0, true]
07-07 18:57:17.907  i: [ExoPlayer][EventLogger] loading [eventTime=272.87, mediaPos=1401.57, window=0, period=0, false]
07-07 18:57:18.283  i: [ExoPlayer][EventLogger] loading [eventTime=273.24, mediaPos=1401.95, window=0, period=0, true]
07-07 18:57:18.285  i: [ExoPlayer][EventLogger] loading [eventTime=273.25, mediaPos=1401.95, window=0, period=0, false]
07-07 18:57:18.594  i: [PlaybackTimeBehaviour] Time: 271230 IsStarted: true
07-07 18:57:18.745  i: [ExoPlayer][EventLogger] loading [eventTime=273.71, mediaPos=1402.41, window=0, period=0, true]
07-07 18:57:18.748  i: [ExoPlayer][EventLogger] loading [eventTime=273.71, mediaPos=1402.41, window=0, period=0, false]
07-07 18:57:19.248  i: [ExoPlayer][EventLogger] loading [eventTime=274.21, mediaPos=1402.92, window=0, period=0, true]
07-07 18:57:19.249  i: [ExoPlayer][EventLogger] loading [eventTime=274.21, mediaPos=1402.92, window=0, period=0, false]
07-07 18:57:19.346  i: [PlaybackTimeBehaviour] Time: 271982 IsStarted: true
07-07 18:57:19.544  i: [ExoPlayer][EventLogger] loading [eventTime=274.51, mediaPos=1403.21, window=0, period=0, true]
07-07 18:57:19.549  i: [ExoPlayer][EventLogger] loading [eventTime=274.51, mediaPos=1403.21, window=0, period=0, false]
07-07 18:57:19.848  i: [PlaybackTimeBehaviour] Time: 272484 IsStarted: true
07-07 18:57:19.930  i: [ExoPlayer][EventLogger] loading [eventTime=274.89, mediaPos=1403.60, window=0, period=0, true]
07-07 18:57:19.932  i: [ExoPlayer][EventLogger] loading [eventTime=274.89, mediaPos=1403.60, window=0, period=0, false]
07-07 18:57:20.539  i: [ExoPlayer][EventLogger] loading [eventTime=275.50, mediaPos=1404.21, window=0, period=0, true]
07-07 18:57:20.545  i: [ExoPlayer][EventLogger] loading [eventTime=275.51, mediaPos=1404.21, window=0, period=0, false]
07-07 18:57:20.599  i: [PlaybackTimeBehaviour] Time: 273234 IsStarted: true
07-07 18:57:21.335  i: [ExoPlayer][EventLogger] loading [eventTime=276.30, mediaPos=1405.00, window=0, period=0, true]
07-07 18:57:21.337  i: [ExoPlayer][EventLogger] loading [eventTime=276.30, mediaPos=1405.00, window=0, period=0, false]
07-07 18:57:21.350  i: [PlaybackTimeBehaviour] Time: 273986 IsStarted: true
07-07 18:57:21.850  i: [PlaybackTimeBehaviour] Time: 274486 IsStarted: true
07-07 18:57:21.910  i: [ExoPlayer][EventLogger] loading [eventTime=276.87, mediaPos=1405.58, window=0, period=0, true]
07-07 18:57:21.911  i: [ExoPlayer][EventLogger] loading [eventTime=276.87, mediaPos=1405.58, window=0, period=0, false]
07-07 18:57:22.575  i: [ExoPlayer][EventLogger] loading [eventTime=277.54, mediaPos=1406.24, window=0, period=0, true]
07-07 18:57:22.579  i: [ExoPlayer][EventLogger] loading [eventTime=277.54, mediaPos=1406.24, window=0, period=0, false]
07-07 18:57:22.601  i: [PlaybackTimeBehaviour] Time: 275237 IsStarted: true
07-07 18:57:23.251  i: [ExoPlayer][EventLogger] loading [eventTime=278.21, mediaPos=1406.92, window=0, period=0, true]
07-07 18:57:23.253  i: [ExoPlayer][EventLogger] loading [eventTime=278.21, mediaPos=1406.92, window=0, period=0, false]
07-07 18:57:23.353  i: [PlaybackTimeBehaviour] Time: 275989 IsStarted: true
07-07 18:57:23.829  i: [ExoPlayer][EventLogger] loading [eventTime=278.79, mediaPos=1407.50, window=0, period=0, true]
07-07 18:57:23.854  i: [PlaybackTimeBehaviour] Time: 276489 IsStarted: true
07-07 18:57:24.605  i: [PlaybackTimeBehaviour] Time: 277241 IsStarted: true
07-07 18:57:25.357  i: [PlaybackTimeBehaviour] Time: 277993 IsStarted: true
07-07 18:57:25.859  i: [PlaybackTimeBehaviour] Time: 278495 IsStarted: true
07-07 18:57:26.611  i: [PlaybackTimeBehaviour] Time: 279247 IsStarted: true
07-07 18:57:26.910  i: [PlaybackTimeBehaviour] Time: 279546 IsStarted: true
07-07 18:57:26.912  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=77809&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=279546&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1410428&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:57:27.362  i: [PlaybackTimeBehaviour] Time: 279998 IsStarted: true
07-07 18:57:27.862  i: [PlaybackTimeBehaviour] Time: 280498 IsStarted: true
07-07 18:57:28.614  i: [PlaybackTimeBehaviour] Time: 281250 IsStarted: true
07-07 18:57:29.366  i: [PlaybackTimeBehaviour] Time: 282001 IsStarted: true
07-07 18:57:29.867  i: [PlaybackTimeBehaviour] Time: 282503 IsStarted: true
07-07 18:57:30.619  i: [PlaybackTimeBehaviour] Time: 283255 IsStarted: true
07-07 18:57:31.370  i: [PlaybackTimeBehaviour] Time: 284006 IsStarted: true
07-07 18:57:31.871  i: [PlaybackTimeBehaviour] Time: 284506 IsStarted: true
07-07 18:57:32.621  i: [PlaybackTimeBehaviour] Time: 285256 IsStarted: true
07-07 18:57:33.371  i: [PlaybackTimeBehaviour] Time: 286007 IsStarted: true
07-07 18:57:33.873  i: [PlaybackTimeBehaviour] Time: 286508 IsStarted: true
07-07 18:57:34.624  i: [PlaybackTimeBehaviour] Time: 287259 IsStarted: true
07-07 18:57:35.375  i: [PlaybackTimeBehaviour] Time: 288011 IsStarted: true
07-07 18:57:35.876  i: [PlaybackTimeBehaviour] Time: 288512 IsStarted: true
07-07 18:57:36.627  i: [PlaybackTimeBehaviour] Time: 289263 IsStarted: true
07-07 18:57:36.952  i: [PlaybackTimeBehaviour] Time: 289587 IsStarted: true
07-07 18:57:36.953  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=67786&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=289587&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1420451&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:57:37.378  i: [PlaybackTimeBehaviour] Time: 290014 IsStarted: true
07-07 18:57:37.879  i: [PlaybackTimeBehaviour] Time: 290515 IsStarted: true
07-07 18:57:38.632  i: [PlaybackTimeBehaviour] Time: 291267 IsStarted: true
07-07 18:57:39.381  i: [PlaybackTimeBehaviour] Time: 292017 IsStarted: true
07-07 18:57:39.882  i: [PlaybackTimeBehaviour] Time: 292518 IsStarted: true
07-07 18:57:40.634  i: [PlaybackTimeBehaviour] Time: 293270 IsStarted: true
07-07 18:57:41.386  i: [PlaybackTimeBehaviour] Time: 294021 IsStarted: true
07-07 18:57:41.886  i: [PlaybackTimeBehaviour] Time: 294522 IsStarted: true
07-07 18:57:42.637  i: [PlaybackTimeBehaviour] Time: 295272 IsStarted: true
07-07 18:57:43.386  i: [PlaybackTimeBehaviour] Time: 296022 IsStarted: true
07-07 18:57:43.887  i: [PlaybackTimeBehaviour] Time: 296523 IsStarted: true
07-07 18:57:44.638  i: [PlaybackTimeBehaviour] Time: 297274 IsStarted: true
07-07 18:57:45.389  i: [PlaybackTimeBehaviour] Time: 298025 IsStarted: true
07-07 18:57:45.890  i: [PlaybackTimeBehaviour] Time: 298526 IsStarted: true
07-07 18:57:46.641  i: [PlaybackTimeBehaviour] Time: 299277 IsStarted: true
07-07 18:57:46.997  i: [PlaybackTimeBehaviour] Time: 299632 IsStarted: true
07-07 18:57:46.999  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=57773&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=299633&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1430464&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:57:47.392  i: [PlaybackTimeBehaviour] Time: 300027 IsStarted: true
07-07 18:57:47.892  i: [PlaybackTimeBehaviour] Time: 300527 IsStarted: true
07-07 18:57:48.643  i: [PlaybackTimeBehaviour] Time: 301279 IsStarted: true
07-07 18:57:49.395  i: [PlaybackTimeBehaviour] Time: 302030 IsStarted: true
07-07 18:57:49.896  i: [PlaybackTimeBehaviour] Time: 302531 IsStarted: true
07-07 18:57:50.647  i: [PlaybackTimeBehaviour] Time: 303283 IsStarted: true
07-07 18:57:51.398  i: [PlaybackTimeBehaviour] Time: 304034 IsStarted: true
07-07 18:57:51.899  i: [PlaybackTimeBehaviour] Time: 304534 IsStarted: true
07-07 18:57:52.650  i: [PlaybackTimeBehaviour] Time: 305286 IsStarted: true
07-07 18:57:53.401  i: [PlaybackTimeBehaviour] Time: 306037 IsStarted: true
07-07 18:57:53.901  i: [PlaybackTimeBehaviour] Time: 306537 IsStarted: true
07-07 18:57:54.653  i: [PlaybackTimeBehaviour] Time: 307289 IsStarted: true
07-07 18:57:55.404  i: [PlaybackTimeBehaviour] Time: 308040 IsStarted: true
07-07 18:57:55.905  i: [PlaybackTimeBehaviour] Time: 308540 IsStarted: true
07-07 18:57:56.656  i: [PlaybackTimeBehaviour] Time: 309292 IsStarted: true
07-07 18:57:57.040  i: [PlaybackTimeBehaviour] Time: 309676 IsStarted: true
07-07 18:57:57.042  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=47556&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=309676&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1440681&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:57:57.407  i: [PlaybackTimeBehaviour] Time: 310043 IsStarted: true
07-07 18:57:57.909  i: [PlaybackTimeBehaviour] Time: 310544 IsStarted: true
07-07 18:57:58.661  i: [PlaybackTimeBehaviour] Time: 311297 IsStarted: true
07-07 18:57:59.412  i: [PlaybackTimeBehaviour] Time: 312048 IsStarted: true
07-07 18:57:59.914  i: [PlaybackTimeBehaviour] Time: 312550 IsStarted: true
07-07 18:58:00.666  i: [PlaybackTimeBehaviour] Time: 313302 IsStarted: true
07-07 18:58:01.417  i: [PlaybackTimeBehaviour] Time: 314053 IsStarted: true
07-07 18:58:01.918  i: [PlaybackTimeBehaviour] Time: 314554 IsStarted: true
07-07 18:58:02.670  i: [PlaybackTimeBehaviour] Time: 315306 IsStarted: true
07-07 18:58:03.422  i: [PlaybackTimeBehaviour] Time: 316058 IsStarted: true
07-07 18:58:03.923  i: [PlaybackTimeBehaviour] Time: 316559 IsStarted: true
07-07 18:58:04.675  i: [PlaybackTimeBehaviour] Time: 317311 IsStarted: true
07-07 18:58:05.427  i: [PlaybackTimeBehaviour] Time: 318063 IsStarted: true
07-07 18:58:05.928  i: [PlaybackTimeBehaviour] Time: 318563 IsStarted: true
07-07 18:58:06.677  i: [PlaybackTimeBehaviour] Time: 319313 IsStarted: true
07-07 18:58:07.080  i: [PlaybackTimeBehaviour] Time: 319716 IsStarted: true
07-07 18:58:07.082  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=37529&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=319716&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1450708&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:58:07.429  i: [PlaybackTimeBehaviour] Time: 320065 IsStarted: true
07-07 18:58:07.931  i: [PlaybackTimeBehaviour] Time: 320566 IsStarted: true
07-07 18:58:08.683  i: [PlaybackTimeBehaviour] Time: 321319 IsStarted: true
07-07 18:58:09.433  i: [PlaybackTimeBehaviour] Time: 322069 IsStarted: true
07-07 18:58:09.934  i: [PlaybackTimeBehaviour] Time: 322569 IsStarted: true
07-07 18:58:10.685  i: [PlaybackTimeBehaviour] Time: 323321 IsStarted: true
07-07 18:58:11.437  i: [PlaybackTimeBehaviour] Time: 324073 IsStarted: true
07-07 18:58:11.937  i: [PlaybackTimeBehaviour] Time: 324573 IsStarted: true
07-07 18:58:12.688  i: [PlaybackTimeBehaviour] Time: 325323 IsStarted: true
07-07 18:58:13.437  i: [PlaybackTimeBehaviour] Time: 326073 IsStarted: true
07-07 18:58:13.939  i: [PlaybackTimeBehaviour] Time: 326575 IsStarted: true
07-07 18:58:14.691  i: [PlaybackTimeBehaviour] Time: 327327 IsStarted: true
07-07 18:58:15.442  i: [PlaybackTimeBehaviour] Time: 328078 IsStarted: true
07-07 18:58:15.943  i: [PlaybackTimeBehaviour] Time: 328579 IsStarted: true
07-07 18:58:16.694  i: [PlaybackTimeBehaviour] Time: 329330 IsStarted: true
07-07 18:58:17.120  i: [PlaybackTimeBehaviour] Time: 329755 IsStarted: true
07-07 18:58:17.121  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=27524&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=329756&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1460713&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:58:17.445  i: [PlaybackTimeBehaviour] Time: 330080 IsStarted: true
07-07 18:58:17.946  i: [PlaybackTimeBehaviour] Time: 330581 IsStarted: true
07-07 18:58:18.697  i: [PlaybackTimeBehaviour] Time: 331333 IsStarted: true
07-07 18:58:19.448  i: [PlaybackTimeBehaviour] Time: 332084 IsStarted: true
07-07 18:58:19.949  i: [PlaybackTimeBehaviour] Time: 332585 IsStarted: true
07-07 18:58:20.700  i: [PlaybackTimeBehaviour] Time: 333336 IsStarted: true
07-07 18:58:21.451  i: [PlaybackTimeBehaviour] Time: 334087 IsStarted: true
07-07 18:58:21.955  i: [PlaybackTimeBehaviour] Time: 334591 IsStarted: true
07-07 18:58:22.705  i: [PlaybackTimeBehaviour] Time: 335341 IsStarted: true
07-07 18:58:23.456  i: [PlaybackTimeBehaviour] Time: 336091 IsStarted: true
07-07 18:58:23.957  i: [PlaybackTimeBehaviour] Time: 336593 IsStarted: true
07-07 18:58:24.709  i: [PlaybackTimeBehaviour] Time: 337345 IsStarted: true
07-07 18:58:25.461  i: [PlaybackTimeBehaviour] Time: 338097 IsStarted: true
07-07 18:58:25.962  i: [PlaybackTimeBehaviour] Time: 338598 IsStarted: true
07-07 18:58:26.713  i: [PlaybackTimeBehaviour] Time: 339349 IsStarted: true
07-07 18:58:27.163  i: [PlaybackTimeBehaviour] Time: 339798 IsStarted: true
07-07 18:58:27.164  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=17504&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=339799&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1470733&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:58:27.464  i: [PlaybackTimeBehaviour] Time: 340100 IsStarted: true
07-07 18:58:27.965  i: [PlaybackTimeBehaviour] Time: 340601 IsStarted: true
07-07 18:58:28.716  i: [PlaybackTimeBehaviour] Time: 341351 IsStarted: true
07-07 18:58:29.466  i: [PlaybackTimeBehaviour] Time: 342102 IsStarted: true
07-07 18:58:29.967  i: [PlaybackTimeBehaviour] Time: 342603 IsStarted: true
07-07 18:58:30.718  i: [PlaybackTimeBehaviour] Time: 343354 IsStarted: true
07-07 18:58:31.469  i: [PlaybackTimeBehaviour] Time: 344105 IsStarted: true
07-07 18:58:31.971  i: [PlaybackTimeBehaviour] Time: 344607 IsStarted: true
07-07 18:58:32.722  i: [PlaybackTimeBehaviour] Time: 345358 IsStarted: true
07-07 18:58:33.473  i: [PlaybackTimeBehaviour] Time: 346109 IsStarted: true
07-07 18:58:33.974  i: [PlaybackTimeBehaviour] Time: 346610 IsStarted: true
07-07 18:58:34.725  i: [PlaybackTimeBehaviour] Time: 347361 IsStarted: true
07-07 18:58:35.476  i: [PlaybackTimeBehaviour] Time: 348112 IsStarted: true
07-07 18:58:35.977  i: [PlaybackTimeBehaviour] Time: 348613 IsStarted: true
07-07 18:58:36.728  i: [PlaybackTimeBehaviour] Time: 349364 IsStarted: true
07-07 18:58:37.207  i: [PlaybackTimeBehaviour] Time: 349843 IsStarted: true
07-07 18:58:37.209  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?audioStreamID=1241888&bufferedTime=7486&duration=2597888&guid=plex%3A%2F%2Fepisode%2F60abd348194926002c41a4f8&key=%2Flibrary%2Fmetadata%2F271132&playbackTime=349843&playQueueItemID=1339410&ratingKey=271132&state=playing&time=1480751&token=...99Vw&X-Plex-Client-Identifier=0504d995d3b0945b-com-plexapp-android&X-Plex-Token=...99Vw&X-Plex-Language=en-ca
07-07 18:58:37.479  i: [PlaybackTimeBehaviour] Time: 350115 IsStarted: true
07-07 18:58:37.981  i: [PlaybackTimeBehaviour] Time: 350617 IsStarted: true
07-07 18:58:38.732  i: [PlaybackTimeBehaviour] Time: 351368 IsStarted: true
07-07 18:58:39.484  i: [PlaybackTimeBehaviour] Time: 352120 IsStarted: true
07-07 18:58:39.986  i: [PlaybackTimeBehaviour] Time: 352622 IsStarted: true
07-07 18:58:40.736  i: [PlaybackTimeBehaviour] Time: 353372 IsStarted: true
07-07 18:58:41.487  i: [PlaybackTimeBehaviour] Time: 354122 IsStarted: true
07-07 18:58:41.988  i: [PlaybackTimeBehaviour] Time: 354624 IsStarted: true
07-07 18:58:42.740  i: [PlaybackTimeBehaviour] Time: 355376 IsStarted: true
07-07 18:58:43.491  i: [PlaybackTimeBehaviour] Time: 356127 IsStarted: true
07-07 18:58:44.242  i: [PlaybackTimeBehaviour] Time: 356878 IsStarted: true
07-07 18:58:44.384  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
07-07 18:58:44.384  i: [TranscodeSession] Media choice updated
07-07 18:58:44.385  i: [TranscodeSession] Pausing...
07-07 18:58:44.385  i: [ExoPlayer][EventLogger] state [eventTime=359.35, mediaPos=1488.04, window=0, period=0, BUFFERING]
07-07 18:58:44.386  i: [ExoPlayer][EventLogger] isPlaying [eventTime=359.35, mediaPos=1488.04, window=0, period=0, false]
07-07 18:58:47.248  i: [PlaybackTimeBehaviour] Time: 359884 IsStarted: true
07-07 18:58:47.251  i: Fetching [method:GET] https://192.168.100.100:32400/:/timeline?
