Player Resumes From End
Server Version#: 1.22.3.4392
Player Version#: 3.4.6
For every song I play and when it comes to the end and starts the next track that is all fine. But when I go back to tracks that have been played they are always starting 10 seconds before the song ends. It is like the client has not told the server that the song is over so the server assumes playback was just stopped so it keeps the place bookmarked. Please do let me know what information I need to provide to help resolve this issue.
Kind regards,
Jack.
It sounds like you might have the “Store track progress” option enabled, found under advanced library settings. This option is intended for libraries containing non-music audio, such as audiobooks, and should not be enabled for music libraries.
Hello there,
Yes, in fact, I do have it enabled! I have just disabled it thank you!
Kind regards,
Simon.
