Plexamp Android Mobile playback issues - track already played start at the end
Server Version#: 1.31.0.6654 (TerraMaster)
Player Version#: 4.6.2 (Android Mobile)
When I play an album for the first time, tracks start at the beginning of the track. If I then replay the album later, some or all the tracks start playing at the end for a few seconds then skip to the next track.
It seems to remember the last played position and starts the track from there and never from the beginning. I have to manually rewind every time. It makes listing to an album from start to finish or any single song impossible.
Is there a way to turn this off so the track always starts from the beginning?
Make sure you haven’t accidentally enabled the “Store track progress” preference in your library settings on the server:
This setting isn’t supposed to be used with music libraries.
Yes, this was set and seems to have sorted it. Thanks, would never have found that myself.
