Playing 1080 on 256MB model B
Hey. I've been trying to get my Pi model B 256MB to work.
SD content plays just fine, most of the time. But sometimes just the audio comes up and the Pi is stuck at menu.
HD content thought, most often does not start at all. And sometimes it starts and quits after some seconds, sometimes with image and sometimes only with audio.
The logs when it doesn't play anything at all is as this:
16:43:11 T:2778723424  NOTICE: Thread Jobworker start, auto delete: true
16:43:18 T:3044667920   ERROR: Keymapping error: no such action '-' defined
16:43:21 T:3044667920   ERROR: Previous line repeats 1 times.
16:43:21 T:3044667920  NOTICE: COMXPlayer: Opening: http://192.168.1.175:32400/library/parts/2391/file.mkv
16:43:21 T:2726294624  NOTICE: Thread COMXPlayer start, auto delete: false
16:43:21 T:2637165664  NOTICE: PlexDirectory::GetDirectory(http://192.168.1.175:32400/library/metadata/1498?checkFiles=1)
16:43:21 T:2726294624  NOTICE: Creating InputStream
16:43:21 T:2726294624   ERROR: Open - Unhandled exception
16:43:21 T:2726294624   ERROR: Open - Error opening http://192.168.1.175:32400/library/parts/2391/file.mkv
16:43:21 T:2726294624   ERROR: COMXPlayer::OpenInputStream - error opening [http://192.168.1.175:32400/library/parts/2391/file.mkv]
16:43:21 T:2726294624  NOTICE: COMXPlayer::OnExit()
16:43:21 T:2726294624  NOTICE: COMXPlayer::OnExit() deleting input stream
16:43:22 T:3044667920  NOTICE: OMXClock using video as reference
16:43:44 T:2801521760  NOTICE: Previous line repeats 1 times.
16:43:44 T:2801521760  NOTICE: None
The Pi has both codec licenses and is running on 100mbit/s cable network.
I've tried many things but still no luck with getting it to run good.
Edit: Opening the mkv links in the logfiles starts the movies in the browser without any problem. So the fault is at the Pi's end.
256Mb Pis are not fully supported yet .. they are a bit trickier to get stable :)
Agreed..  I'm on 0.1.32 and going down the list all the way to 0.1.28 which worked flawlessly.
