Is it possible to choose the aux or line in as an audio source in Plex? I’m thinking about a situation in which you have an external audio source plugged in as the (analog) line-in on a device that has Plex Media Server on it, and you want Plex to effectively “stream” that audio source and output it directly.
If this isn’t possible, does anyone have any suggestions on an application that can take the line-in source and present it as a device that PMS is compatible with as an audio source in some way?
