So the new Plex is great when it comes to support for music - and albums.
However, when running Plexconnect on my atv3 I am not able to play entire albums, just by selecting them. I only get to play the first track, then I have to go back and select the next track etc. It also seems the time counter isn’t working properly - total song length is not showing, and the time bar is not moving while the song is playing.
I have the latest version of Plexconnect running on a Mac mini with Yosemite. Is this supposed to work? Complete album playback, that is? Or is it just not working?
It should work. Continuous playing with like the PLAY button, one song with SELECT. Or the other way around? Try shuffle to get the complete album in random order.
Song length/time/progress bar issues are known - this comes up especially with transcoded files. Having no good idea about the root cause, I tend to blame the transcoder/PMS file handling.
Doesn’t work, strangely enough. When I press “Play” I just get the option to start the one song, when I use “Select” I just get the annoyed Apple “clonk” - telling me it’s an invalid command. Everything else is working fine.
My bad… continuous play to be selected with SELECT, single song with PLAY. I think we changed it on the way - to get quicker access to the “play all” feature.
Hm. Could you please explain which option and/or starting at which menu you are seeing this?
here --> jailbroken ATV2 with PlexConnect. Plex server is on a Synology NAS.
I have the same problem with music. No continous playback.
If I use Select it only plays one (it also says 1 of 1) song.
I cannot use Play, as it will not respond.
I’m stuck and cannot find a solution here.
Can anyone please help me on this? Would be very nice. Thanks a lot
ATV 2? IOS? With older versions we never found a way to do continous playback. I am not sure yet which iOS has been the skipping point… do you have Apple’s beats app?
Sorry, everything before iOS 7 seems to need the plist files for music/track selection. No documentation, no examples, hard to debug… I am pretty sure, there is a way to download playlists, or complete albums, but we never found out how.
With iOS 7, Apple added a XML version of that interface - it works much better, and with Beats there even were some examples available.
