Playing Movies keeps on loading.
Hello,
I setup plexconnect and it works like a charm.  Thanks for all of your hardwork on this I really appreciate it.  The issue that is happening with the plexconnect and appletv3 right now is that everytime I play a video it keeps on loading.  Like play then loading then play then loading..
I have windows 7 where the PMS is installed which is connected via LAN.  My appleTV is connected via wifi and my router is cisco E1200.  Is there any problem or settings that I need to change to have a better movie experience?
Thanks!
Your wifi may be overloaded, does this only happen with PlexConnect? How about native iTunes streaming? What kind of movies/codecs - are they direct streamed or transcoded?
Just questions... we need more data. Plus logfile... see wiki.
I did not try the native iTunes streaming though.  The codec is forcely transcoded,  I will try and get more log files next time since I wanted to watch the movie so I connected my apple tv to a LAN cable.  Thanks! ;)
So... with the LAN cable it worked? And you complain about an PlexConnect issue? Hello?
