Server Version#:1.26.2.5797 (Synology DiskStation DS920)
Player Version#:9.2.3.32818(966a0f23)
Ok so first off this isn’t a Shield sever issue, but there is only the android TV and Server Nvidia Shield tags to work with, but this is an Nvidia Shield Player problem. Not sure if the Nvidia Shield has a separate version of the plex player from Android TV or not.
Ok on to the issue. It’s a simple bug. Playlists don’t work how they are supposed to. If i select an item on a playlist or start a playlist it plays the file sure, but then it plays the next item in its orginal order not the next item in the playlist. So for example I have an Arrowverse playlist that plays just fine on my Xbox Series X and other devices, but when i try to play it on either of my two Shields it wants to play the next episode in that series instead of playing the next episode in my chronological order playlist I made. The same is true of all my other playlists, but on when i try them on my Shields. It doesn’t even show my custom artwork for the playlist poster, it just shows the original collage from when the playlist originally was made.
