I’m using the PlexAmp on my desktop and iPhone to listen to my library. I also use the 1-star-rating option. Is there a way to create a smart playlist with all my starred tracks?
I do the same and its pretty awesome.
https://www.ryananddebi.com/2019/08/26/plex-how-to-create-smart-auto-updating-music-playlists/
Yes, I know that you can create smart playlists based on different criteria. But a smart playlist based on track rating seems only to work if you use the 5-star-rating option. I just like the 1-star-rating option in PlexAmp more, but it seems, that this option isn’t (yet?) integrated in Plex server.
Not true, the single star
is exactly the same as a 5-star rating or (10.0)
Thank you so much. I tried it with filtering by 5-star rating before, but my server showed my no tracks. After trying it again now it worked. Maybe my server had a hiccup the first time.
