Playlist inconvenient features
Using Plex player on amazon fireTVstick.
Hi, I recently started using the playlist feature. It is useful to put a bunch of movies in the list and choose shuffle if I am not sure which movie to watch first.
Issue 1:
I have the option to view 1 trailer set prior to a movie playing, but this option does not work if a movie is started from within the playlist.
Issue 2:
When a movie is started from within a playlist and is subsequently stopped and you then choose the movie again from within the playlist, you are not given the option to continue where you left off. The movie always restarts from the beginning. If you then find the movie within the movies section it will still start from the beginning.
Also, it would be useful if there is an option to choose how many movies to play within a playlist. If there are 10 movies in a playlist and I only want to play say 2 on shuffle, then it should stop after playing 2 random playlist movies.
