When using my nvidia shield to access Plex and I view the options on the left (watchlist, TV, music, movies, etc), Playlists does not appear. I have to go to the bottom where I find my Plex server name, and under that I can find Playlists. I set all this up over 7 years ago so I don’t remember how I originally set up Plex, but how do I correct this. It’s not a problem when on use the app on my laptop or iphone, only the Shield.
You go to MORE and see all the libraries/sources under your server name.
There should be a pin icon to the left of them, the one that are filled in are pinned to your home screen sidebar, the ones that are just an outline are not.
Move down to focus on Playlists and move left to focus on then select the menu for it (the three vertical dots) where you can select to pin it sidebar
It all makes sense now. Using the server name dropdown allows you to make changes to the default library selection on the left. Kind of like a settings function. Are there any other helpful things to know that I haven’t wised up to yet?
Thanks for the help !
