Playlist Shuffle TV Shows Not Playing Next Episode
I added several of my favorite shows to a playlist to shuffle while I sleep. I have a new Firestick 4k (not the max) running whatever the Stable Version is right now (1/25/2022).
When I click Shuffle on the Playlist (which navigating to is broken also on the Firestick), it plays the first episode just fine, but the episodes do not proceed to the next and are not getting marked as watched. I tried with 3 different episodes in the same playlist and I could not get past the black screen at the end of the video. I have 5 other/separate playlist shows doing Shuffle this does not happen. This is the only one that does it.
Unfortunately, I do not have logs to provide at the moment. I can provide the file information for one of the files.
Codec HEVC
Bitrate 1637 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 1080
Coded Width 1920
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 1080
Level 4.1
Profile main 10
Ref Frames 1
Width 1920
Display Title 1080p (HEVC Main 10)
Extended Display Title 1080p (HEVC Main 10)
Codec AAC
Channels 6
Bitrate 556 kbps
Audio Channel Layout 5.1
Profile lc
Sampling Rate 48000 Hz
Title Surround
Display Title Unknown (AAC 5.1)
Extended Display Title Surround (AAC 5.1)
Codec SRT
Language English
Language Tag en
Display Title English (SRT)
Extended Display Title English (SRT)
