had no problems with playlists in 0.6. Since upgrading to 0.7 the next item in a playlist does not always start automatically. Current item finishes and instead of starting the next item I’m back in the view where I have to select the next item manually. Very anoying during work outs
Is this a bug or did I miss a setting? Since it sometimes works I guess a bug.
Music, photo, video? Can you please provide more information, have you checked the logs?
Ok, did some further testing today. Playlist looks like this:
Item1 90 min
Item2 42 min
Item3 42 min
I have already watched 60 min of item1 yesterday. So today I resumed at 60 min. After item1finished plex did not start playing item2. I had to start manually. After item2 finished, item3 startet automatically (as it should).
In the log file of the server I found the following:
Aug 28, 2015 16:27:11 [0x10c5cb000] ERROR - CERT: Error in TLS handshake: sslv3 alert bad certificate
(repeated a few times)
Aug 28, 2015 16:33:33 [0x10df72000] WARN - Sync: librarySectionChanged for unknown library section -1
Aug 28, 2015 16:33:37 [0x10c5cb000] ERROR - Error writing media: 32 - Broken pipe
Aug 28, 2015 16:33:37 [0x10d2f5000] ERROR - Had trouble breaking playQueueVersion
Aug 28, 2015 16:33:37 [0x10d2f5000] ERROR - ERROR: Parsing request failed.
Aug 28, 2015 16:34:07 [0x1088aa000] ERROR - Had trouble breaking playQueueVersion
Aug 28, 2015 16:34:07 [0x1088aa000] ERROR - ERROR: Parsing request failed.
Aug 28, 2015 16:34:38 [0x10cba5000] ERROR - Had trouble breaking playQueueVersion
Aug 28, 2015 16:34:38 [0x10cba5000] ERROR - ERROR: Parsing request failed.
Aug 28, 2015 16:35:08 [0x10c83b000] ERROR - Had trouble breaking playQueueVersion
Aug 28, 2015 16:35:08 [0x10c83b000] ERROR - ERROR: Parsing request failed.
The last 2 lines keep repeating every 30 seconds.
At the time were the switch from item2 to item3 was the errors stop and the following line appears:
Aug 28, 2015 17:08:16 [0x1088aa000] WARN - Range could not be satisfied 7931527653 - 0 (total size=7931527653)
Any idea what is going on? Are the any logs from Rasplex I should post here?
There seems to be something strange going on with the login process right after starting the Pi. I can see my libraries and in the top right corner I see my user name. So it appears that I’m logged in. Put if I select the menu “far to the left” I don’t see “switch user” but “sign in”. If I sign in the error messages disappear.
But playlists still won’t continue with the next video if I start my playlist by resuming an already started item.
Are there any log files on the Pi I can look for the problem?
It just occurred to me, that a test on my “real” computer would be a good thing. And there the problem is too. So it is not a problem restricted to the Pi but either the Plex server or every player.
