Please add server setting convert automatically default
I was looking for a way to set convert automatically for all streams as default. There isn’t any as far as I can tell. There are users who have the appropriate equipment to play and do anything without restrictions and this would help tremendously.
I hate having to always go to the client and select that setting manually. Thanks you for the consideration. I have read in many google searches that there is an abundance of users wanting this.
This is Plexweb - as an example, but most Plex Apps have this setting wherein you would activate it - and it would be ON. Always:
You’ll note mine is off.
Thanks for that. It isn’t always working I set maximum and I still have to use the client invocation of the convert automatically to get it to work.
The setting must be made in each Client App.
There is no Blanket Server Setting to achieve this. Unfortunately.
That is what I am asking for as a feature addition :slight_smile:
by the way thank you for offering your insight and suggestion to the issue :slight_smile:
You and 339(million) other people:
Been tryin that since August 2019 - so… good luck.
Some of that may help you, may not, but to date it’s not had to file a flight plan so we wait and hope to the sound of crickets.
This should not be made to be a one way offering. We should have anything and everything available to us as it relates to this feature. Some of us don’t worry about internet connection speed and personally I do everything on a 10g network for the most part.
We need the ability to setup the server to suit our needs. :slight_smile:
The server would need to control the clients as to starting quality. I don’t see it being a major programming event.
Thanks again :slight_smile:
Here you go… please comment/vote in the original/existing thread.
Creating duplicate suggestions will result in votes being distracted/dispersed and both suggestions not getting any attention. Therefore I’ll close this one.
That suggestion is so convoluted… No wonder nothing happens. My post is way more effective at getting the suggestion out. Blanket posts get overlooked.
I do like the gist of that post though… :slight_smile:
