Please help - can't record using DVR
Server Version#: Version 1.22.2.4282
Tuner Make/Model: HDhomerun Connect Duo
Guide/Lineup name: Local Broadcast Listings
Using XMLTV?: no
Channel number/Name: all
Please help.
Before the Guide source changed my DVR worked very well. Now nothing records properly. Also when I watch live TV using the guide it plays for about 10 minutes and then freezes.
Have you recreated your scheduled recordings after the switchover to the new EPG provider at the end of 2021 ?
See first post in this thread Live TV EPG - The update you’ve been waiting for
If you have recreated the schedule but recordings still fail - please run with debug logging enabled and capture logs for when the issue arises
see
Thanks for your reply.
Last night I updated the firmware on my HD homerun (FIY I had to download it from the website and manually install on the device even though it’s set to auto update). After this I tried a recording and it worked!
I have more recordings scheduled over the next few days so I would like to keep this open with you until I get a few more successful recordings.
Thanks again,
Mark
Hi - yes I recreated my scheduled recordings after the switchover to the new EPG provider at the end of 2020 (several times).
iMac Plex Media Server Logs_2021-04-26_21-42-28.zip (4.8 MB)
Server Version#: Version 1.22.3.4392
OS 11.2.3
