Please Help: Plex keeps crashing!
Server Version#: 1.26.0.5715
Player Version#: ALL
I am running PMS on unRaid in a docker container. Going back multiple versions, the server would crash sporadically and the only way to fix it is to restart the container. No version has been stable, it would run for sometimes a couples hours, sometimes a couple days. The logs attached are from the most recent crash that occurred today.
My docker is running on unRaid 6.10.0 rc4 in host networking mode on an AMD EPYC CPU with a P2000 GPU for transcoding. This issue was happening on unRaid 6.9 as well. No other dockers have had any issues.
That logs looks generally fine except some slow db queries it only seems to be about 8 minutes of time then logs were gathered. It does not look like the crash would have been in previous one as the normal start up sequences don’t appear to be in that one as it was still writing logs.
The crash might be in one of the older ones. The higher the number at the end the older the log.
Looks like I was able to isolate the issue. I had “Push Notifications” enabled on my server and it would crash during busy times. I disabled that setting and it seems to be stable again.
Has there been any reported issues with that feature?
