Please Help! - WebServer_SSL Not Alive. Shutting Down.
Hey guys, just purchased an ATV3 and figured would try to install PlexConnect. I've been at it for almost 2 days now with no luck. I do have multiple ATV2's that I've jailbroken and installed everything from A-Z on, yet I just can't get this one working?? Anyways, here is the error log I'm getting in terminal:
Last login: Mon Jan  6 23:07:02 on ttys000
patricks-imac:~ Greenwell$ cd /Users/Greenwell/Downloads/PlexConnect-master
patricks-imac:PlexConnect-master Greenwell$ sudo ./PlexConnect.py
Password:
23:14:54 PlexConnect: ***
23:14:54 PlexConnect: PlexConnect
23:14:54 PlexConnect: Press CTRL-C to shut down.
23:14:54 PlexConnect: started: 23:14:54
23:14:54 PlexConnect: Version: 0.3.1+
23:14:54 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
23:14:54 PlexConnect: Host OS: darwin
23:14:54 PlexConnect: IP_self: 192.168.1.23
23:14:54 DNSServer: started: 23:14:54
23:14:54 DNSServer: ***
23:14:54 DNSServer: DNSServer: Serving DNS on 192.168.1.23 port 53.
23:14:54 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.23
23:14:54 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
23:14:54 DNSServer: forward other to higher level DNS: 8.8.8.8
23:14:54 WebServer: started: 23:14:54
23:14:54 WebServer: ***
23:14:54 WebServer: WebServer: Serving HTTP on 192.168.1.23 port 80.
23:14:55 WebServer: started: 23:14:55
23:14:55 WebServer: Failed to access certificate: /Users/Greenwell/Downloads/PlexConnect-master/./assets/certificates/trailers.pem
23:14:55 PlexConnect: WebServer_SSL not alive. Shutting down.
23:14:55 PlexConnect: Shutting down.
23:14:55 WebServer: Shutting down.
23:14:59 DNSServer: Shutting down.
23:14:59 PlexConnect: shutdown
Of note, I have already installed the certificate on my ATV3 using Apple Configurator and was able to get the "green check." I have NOT modified any files in the PlexConnect-master folder, as it seems some tutorials say to and others not? I am running 6.0.2, which I know is "new" but plenty of people out there are running it fine. Any help would be great! Thank you so so much
Patrick
Error is here;
The path looks a little strange with the /./ what’s your settings.cfg have in it?
What permissions do you have on the certificates folder?
Is the trailers.pem file in that folder?
...path should be fine. It's a concanation of the PlexConnect path with the second part found in the settings. Even with the strange looking "/./" it typically works ok.
So I just got home from work, what exactly do you all need me to do? I feel like I have followed many different various "guides," all of which have told me conflicting instructions. Is there a single, go-to one that I should follow step for step? Again, I am running 6.0.2 -> I assume that this is the reason I need to perform the certificate steps while the official wiki-how-to doesn't include this? But that wiki also doesn't include changing anything in the Settings.py file, while others do? Again, will listen to everyone/everything and I am home the rest of the night. Really appreciate the help! Can copy and paste whatever you need.
*Of note, I have the PlexConnect Master folder, trailers.cer, trailers.key, trailers.pem all as individual files on my desktop. Do I need to combine then into a single location, or just keep them here? Sorry if a stupid question
Start over and use the wiki guide only!
It does include the certs bit so you must have missed it.
Ok so started over and I finally got a successful terminal launch of PlexConnect (I think it was because I hadn't copied the trailers.___ files into my PlexConnect master folder (assets, certificates section). So I have the terminal saying PlexConnect is up and running. And when I hit trailers on AppleTV, it says "Accessing Trailers" with the spinning circle. However, it does this for a very long time. Then I actually do see the Plex options (Movies, TV Shows, Music, etc). But again, when I click on one, it again shows "Accessing Trailers" with the circle spinning, for a long time. And then it usually just gets stuck. Does this take so long for everybody? Or maybe just the first time? I guess I'm a little confused. Here is what I have copied from the terminal log:
Last login: Tue Jan  7 18:01:27 on console
patricks-imac:~ Greenwell$ sudo "/Applications/PlexConnect-master/PlexConnect.py"
Password:
18:14:35 PlexConnect: ***
18:14:35 PlexConnect: PlexConnect
18:14:35 PlexConnect: Press CTRL-C to shut down.
18:14:35 Settings: add section PlexConnect
18:14:35 Settings: add option port_pms=32400
18:14:35 Settings: add option port_webserver=80
18:14:35 Settings: add option ip_plexconnect=0.0.0.0
18:14:35 Settings: add option certfile=./assets/certificates/trailers.pem
18:14:35 Settings: add option ip_dnsmaster=8.8.8.8
18:14:35 Settings: add option loglevel=Normal
18:14:35 Settings: add option enable_dnsserver=True
18:14:35 Settings: add option logpath=.
18:14:35 Settings: add option ip_pms=192.168.178.10
18:14:35 Settings: add option enable_plexgdm=True
18:14:35 Settings: add option hosttointercept=trailers.apple.com
18:14:35 Settings: add option port_ssl=443
18:14:35 Settings: add option enable_webserver_ssl=True
18:14:35 Settings: add option prevent_atv_update=True
18:14:35 Settings: add option port_dnsserver=53
18:14:35 Settings: add option enable_plexconnect_autodetect=True
18:14:35 PlexConnect: started: 18:14:35
18:14:35 PlexConnect: Version: 0.3.1+
18:14:35 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
18:14:35 PlexConnect: Host OS: darwin
18:14:35 PlexConnect: IP_self: 192.168.1.23
18:14:35 DNSServer: started: 18:14:35
18:14:35 DNSServer: ***
18:14:35 DNSServer: DNSServer: Serving DNS on 192.168.1.23 port 53.
18:14:35 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.23
18:14:35 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
18:14:35 DNSServer: forward other to higher level DNS: 8.8.8.8
18:14:35 WebServer: started: 18:14:35
18:14:35 WebServer: ***
18:14:35 WebServer: WebServer: Serving HTTP on 192.168.1.23 port 80.
18:14:35 WebServer: WebServer: Serving HTTPS on 192.168.1.23 port 443.
18:19:19 DNSServer: DNS request received!
18:19:19 DNSServer: Source: ('192.168.1.124', 63142)
18:19:19 DNSServer: Domain: itunes.apple.com
18:19:19 DNSServer: ***forward request
18:19:19 DNSServer: -> DNS response from higher level
18:19:19 DNSServer: Source: ('192.168.1.124', 60561)
18:19:19 DNSServer: Domain: s.mzstatic.com
18:19:20 DNSServer: DNS request received!
18:19:20 DNSServer: Source: ('192.168.1.124', 60561)
18:19:20 DNSServer: Domain: s.mzstatic.com
18:19:20 DNSServer: ***forward request
18:19:20 DNSServer: -> DNS response from higher level
18:19:20 DNSServer: Source: ('192.168.1.124', 65279)
18:19:20 DNSServer: Domain: local
18:19:21 DNSServer: -> DNS response from higher level
18:19:21 DNSServer: DNS request received!
18:19:21 DNSServer: Source: ('192.168.1.124', 55379)
18:19:21 DNSServer: Domain: local
18:19:21 DNSServer: ***forward request
18:19:23 DNSServer: DNS request received!
18:19:23 DNSServer: Source: ('192.168.1.124', 60561)
18:19:23 DNSServer: Domain: s.mzstatic.com
18:19:23 DNSServer: ***forward request
18:19:23 DNSServer: -> DNS response from higher level
18:19:37 DNSServer: DNS request received!
18:19:37 DNSServer: Source: ('192.168.1.124', 58852)
18:19:37 DNSServer: Domain: init.itunes.apple.com
18:19:37 DNSServer: ***forward request
18:19:37 DNSServer: -> DNS response from higher level
18:19:37 DNSServer: Source: ('192.168.1.124', 60415)
18:19:37 DNSServer: Domain: e673.e9.akamaiedge.net
18:19:37 DNSServer: Source: ('192.168.1.124', 49192)
18:19:37 DNSServer: Domain: buy.itunes.apple.com
18:19:38 DNSServer: DNS request received!
18:19:38 DNSServer: Source: ('192.168.1.124', 49192)
18:19:38 DNSServer: Domain: buy.itunes.apple.com
18:19:38 DNSServer: ***forward request
18:19:38 DNSServer: -> DNS response from higher level
18:21:21 DNSServer: DNS request received!
18:21:21 DNSServer: Source: ('192.168.1.124', 59053)
18:21:21 DNSServer: Domain: p05-keyvalueservice.icloud.com
18:21:21 DNSServer: ***forward request
18:21:26 DNSServer: DNS request received!
18:21:26 DNSServer: Source: ('192.168.1.124', 60520)
18:21:26 DNSServer: Domain: init.itunes.apple.com
18:21:26 DNSServer: ***forward request
18:21:31 DNSServer: DNS request received!
18:21:31 DNSServer: Source: ('192.168.1.124', 59053)
18:21:31 DNSServer: Domain: p05-keyvalueservice.icloud.com
18:21:31 DNSServer: ***forward request
18:21:36 DNSServer: DNS request received!
18:21:36 DNSServer: Source: ('192.168.1.124', 60520)
18:21:36 DNSServer: Domain: init.itunes.apple.com
18:21:36 DNSServer: ***forward request
18:21:41 DNSServer: DNS request received!
18:21:41 DNSServer: Source: ('192.168.1.124', 64924)
18:21:41 DNSServer: Domain: local
18:21:41 DNSServer: ***forward request
18:21:46 DNSServer: DNS request received!
18:21:46 DNSServer: Source: ('192.168.1.124', 60421)
18:21:46 DNSServer: Domain: local
18:21:46 DNSServer: ***forward request
18:21:51 DNSServer: DNS request received!
18:21:51 DNSServer: Source: ('192.168.1.124', 60421)
18:21:51 DNSServer: Domain: local
18:21:51 DNSServer: ***forward request
18:21:51 DNSServer: -> DNS response from higher level
18:21:51 DNSServer: Source: ('192.168.1.124', 59053)
18:21:51 DNSServer: Domain: p05-keyvalueservice.icloud.com
18:21:51 DNSServer: Source: ('192.168.1.124', 60520)
18:21:51 DNSServer: Domain: init.itunes.apple.com
18:21:51 DNSServer: Source: ('192.168.1.124', 50918)
18:21:51 DNSServer: Domain: time.apple.com
18:21:51 DNSServer: Source: ('192.168.1.124', 51523)
18:21:51 DNSServer: Domain: init-p01st.push.apple.com
18:21:51 DNSServer: Source: ('192.168.1.124', 59412)
18:21:51 DNSServer: Domain: push.apple.com
18:21:51 DNSServer: Source: ('192.168.1.124', 52413)
18:21:51 DNSServer: Domain: 17-courier.push.apple.com
18:21:51 DNSServer: Source: ('192.168.1.124', 51641)
18:21:52 DNSServer: DNS request received!
18:21:52 DNSServer: Source: ('192.168.1.124', 53580)
18:21:52 DNSServer: Domain: xp.apple.com
18:21:52 DNSServer: ***forward request
18:21:52 DNSServer: -> DNS response from higher level
18:21:52 DNSServer: Source: ('192.168.1.124', 53192)
18:21:52 DNSServer: Domain: itunes.apple.com
18:21:52 DNSServer: Source: ('192.168.1.124', 58709)
18:21:52 DNSServer: Domain: e673.e9.akamaiedge.net
18:21:59 DNSServer: DNS request received!
18:21:59 DNSServer: Source: ('192.168.1.124', 59161)
18:21:59 DNSServer: Domain: configuration.apple.com
18:21:59 DNSServer: ***forward request
18:21:59 DNSServer: -> DNS response from higher level
18:22:00 DNSServer: DNS request received!
18:22:00 DNSServer: Source: ('192.168.1.124', 63949)
18:22:00 DNSServer: Domain: a3.mzstatic.com
18:22:00 DNSServer: ***forward request
18:22:00 DNSServer: -> DNS response from higher level
18:22:00 DNSServer: Source: ('192.168.1.124', 59267)
18:22:00 DNSServer: Domain: a1.mzstatic.com
18:22:00 DNSServer: Source: ('192.168.1.124', 50989)
18:22:00 DNSServer: Domain: a5.mzstatic.com
18:22:01 DNSServer: DNS request received!
18:22:01 DNSServer: Source: ('192.168.1.124', 57307)
18:22:01 DNSServer: Domain: a2.mzstatic.com
18:22:01 DNSServer: ***forward request
18:22:01 DNSServer: -> DNS response from higher level
18:22:13 DNSServer: DNS request received!
18:22:13 DNSServer: Source: ('192.168.1.124', 53064)
18:22:13 DNSServer: Domain: e673.e9.akamaiedge.net
18:22:13 DNSServer: ***forward request
18:22:13 DNSServer: -> DNS response from higher level
18:22:13 DNSServer: Source: ('192.168.1.124', 57938)
18:22:13 DNSServer: Domain: buy.itunes.apple.com
18:22:14 DNSServer: DNS request received!
18:22:14 DNSServer: Source: ('192.168.1.124', 59570)
18:22:14 DNSServer: Domain: p21-buy.itunes.apple.com
18:22:14 DNSServer: ***forward request
18:22:14 DNSServer: -> DNS response from higher level
18:22:15 DNSServer: DNS request received!
18:22:15 DNSServer: Source: ('192.168.1.124', 56972)
18:22:15 DNSServer: Domain: p8-buy.itunes.apple.com
18:22:15 DNSServer: ***forward request
18:22:15 DNSServer: -> DNS response from higher level
18:22:35 DNSServer: DNS request received!
18:22:35 DNSServer: Source: ('192.168.1.124', 64289)
18:22:35 DNSServer: Domain: e673.e9.akamaiedge.net
18:22:35 DNSServer: ***forward request
18:22:35 DNSServer: -> DNS response from higher level
18:23:15 DNSServer: DNS request received!
18:23:15 DNSServer: Source: ('192.168.1.124', 64289)
18:23:15 DNSServer: Domain: e673.e9.akamaiedge.net
18:23:15 DNSServer: ***forward request
18:23:15 DNSServer: -> DNS response from higher level
18:23:16 DNSServer: DNS request received!
18:23:16 DNSServer: Source: ('192.168.1.124', 52097)
18:23:16 DNSServer: Domain: s.mzstatic.com
18:23:16 DNSServer: ***forward request
18:23:16 DNSServer: -> DNS response from higher level
18:23:20 DNSServer: DNS request received!
18:23:20 DNSServer: Source: ('192.168.1.124', 52875)
18:23:20 DNSServer: Domain: trailers.apple.com
18:23:20 DNSServer: ***intercept request
18:23:20 DNSServer: -> DNS response: 192.168.1.23
18:23:20 WebServer: serving /js/application.js
18:23:20 WebServer: serving .xml: /
18:23:20 ATVSettings: add section DY6KFQZSFF54
18:23:20 PlexAPI: ***
18:23:20 PlexAPI: looking up Plex Media Server
18:23:21 PlexAPI: GDM: Servers discovered: 1
18:23:21 PlexAPI: Servers (local+MyPlex): 1
18:23:21 WebServer: serving .xml: /PlexConnect.xml
18:23:21 WebServer: serving /js/utils.js
18:23:21 WebServer: serving .xml: /library/sections
18:23:22 WebServer: serving .xml: /library/sections/1/recentlyAdded
18:24:37 DNSServer: DNS request received!
18:24:37 DNSServer: Source: ('192.168.1.124', 61888)
18:24:37 DNSServer: Domain: init-p01st.push.apple.com
18:24:37 DNSServer: ***forward request
18:24:37 DNSServer: -> DNS response from higher level
18:24:37 DNSServer: Source: ('192.168.1.124', 50615)
18:24:37 DNSServer: Domain: local
18:24:37 DNSServer: Source: ('192.168.1.124', 59104)
18:24:37 DNSServer: Domain: 14-courier.push.apple.com
18:24:40 DNSServer: DNS request received!
18:24:40 DNSServer: Source: ('192.168.1.124', 51504)
18:24:40 DNSServer: Domain: itunes.apple.com
18:24:40 DNSServer: ***forward request
18:24:40 DNSServer: -> DNS response from higher level
18:24:41 DNSServer: DNS request received!
18:24:41 DNSServer: Source: ('192.168.1.124', 51504)
18:24:41 DNSServer: Domain: itunes.apple.com
18:24:41 DNSServer: ***forward request
18:24:41 DNSServer: -> DNS response from higher level
18:25:32 DNSServer: DNS request received!
18:25:32 DNSServer: Source: ('192.168.1.124', 49457)
18:25:32 DNSServer: Domain: trailers.apple.com
18:25:32 DNSServer: ***intercept request
18:25:32 DNSServer: -> DNS response: 192.168.1.23
18:25:33 WebServer: serving /js/application.js
18:25:35 DNSServer: DNS request received!
18:25:35 DNSServer: Source: ('192.168.1.124', 56840)
18:25:35 DNSServer: Domain: a3.mzstatic.com
18:25:35 DNSServer: ***forward request
18:25:36 DNSServer: -> DNS response from higher level
18:25:56 WebServer: serving .xml: /
18:25:56 PlexAPI: ***
18:25:56 PlexAPI: looking up Plex Media Server
18:25:57 PlexAPI: GDM: Servers discovered: 1
18:25:57 PlexAPI: Servers (local+MyPlex): 1
18:25:57 WebServer: serving .xml: /PlexConnect.xml
18:25:57 WebServer: serving /js/utils.js
18:25:57 WebServer: serving .xml: /library/sections
18:25:58 WebServer: serving .xml: /library/sections/1/recentlyAdded
18:26:03 DNSServer: DNS request received!
18:26:03 DNSServer: Source: ('192.168.1.124', 63688)
18:26:03 DNSServer: Domain: a2.mzstatic.com
18:26:03 DNSServer: ***forward request
18:26:03 DNSServer: -> DNS response from higher level
18:26:03 DNSServer: Source: ('192.168.1.124', 49374)
18:26:03 DNSServer: Domain: a5.mzstatic.com
18:26:10 WebServer: serving .xml: /library/sections/1
18:27:11 DNSServer: DNS request received!
18:27:11 DNSServer: Source: ('192.168.1.124', 61042)
18:27:11 DNSServer: Domain: trailers.apple.com
18:27:11 DNSServer: ***intercept request
18:27:11 DNSServer: -> DNS response: 192.168.1.23
18:27:36 WebServer: serving /js/utils.js
18:27:36 WebServer: serving /js/updateXML.js
18:29:33 DNSServer: DNS request received!
18:29:33 DNSServer: Source: ('192.168.1.124', 52945)
18:29:33 DNSServer: Domain: 44-courier.push.apple.com
18:29:33 DNSServer: ***forward request
18:29:33 DNSServer: -> DNS response from higher level
18:29:34 DNSServer: DNS request received!
18:29:34 DNSServer: Source: ('192.168.1.124', 60772)
18:29:34 DNSServer: Domain: local
18:29:34 DNSServer: ***forward request
18:29:34 DNSServer: -> DNS response from higher level
18:29:34 DNSServer: Source: ('192.168.1.124', 53546)
18:29:36 DNSServer: DNS request received!
18:29:36 DNSServer: Source: ('192.168.1.124', 55302)
18:29:36 DNSServer: Domain: buy.itunes.apple.com
18:29:36 DNSServer: ***forward request
18:29:36 DNSServer: -> DNS response from higher level
18:29:37 DNSServer: DNS request received!
18:29:37 DNSServer: Source: ('192.168.1.124', 56910)
18:29:37 DNSServer: Domain: p8-buy.itunes.apple.com
18:29:37 DNSServer: ***forward request
18:29:37 DNSServer: -> DNS response from higher level
18:29:39 DNSServer: DNS request received!
18:29:39 DNSServer: Source: ('192.168.1.124', 57141)
18:29:39 DNSServer: Domain: init.itunes.apple.com
18:29:39 DNSServer: ***forward request
18:29:39 DNSServer: -> DNS response from higher level
18:29:39 DNSServer: Source: ('192.168.1.124', 49394)
18:29:39 DNSServer: Domain: itunes.apple.com
18:29:41 DNSServer: DNS request received!
18:29:41 DNSServer: Source: ('192.168.1.124', 64145)
18:29:41 DNSServer: Domain: p2-buy.itunes.apple.com
18:29:41 DNSServer: ***forward request
18:29:41 DNSServer: -> DNS response from higher level
18:29:42 DNSServer: DNS request received!
18:29:42 DNSServer: Source: ('192.168.1.124', 64145)
18:29:42 DNSServer: Domain: p2-buy.itunes.apple.com
18:29:42 DNSServer: ***forward request
18:29:42 DNSServer: -> DNS response from higher level
18:30:47 DNSServer: DNS request received!
18:30:47 DNSServer: Source: ('192.168.1.124', 62115)
18:30:47 DNSServer: Domain: init.itunes.apple.com
18:30:47 DNSServer: ***forward request
18:30:47 DNSServer: -> DNS response from higher level
18:30:48 DNSServer: DNS request received!
18:30:48 DNSServer: Source: ('192.168.1.124', 63082)
18:30:48 DNSServer: Domain: xp.apple.com
18:30:48 DNSServer: ***forward request
18:30:48 DNSServer: -> DNS response from higher level
18:30:48 DNSServer: Source: ('192.168.1.124', 53794)
18:30:48 DNSServer: Domain: itunes.apple.com
18:30:49 DNSServer: DNS request received!
18:30:49 DNSServer: Source: ('192.168.1.124', 56787)
18:30:49 DNSServer: Domain: configuration.apple.com
18:30:49 DNSServer: ***forward request
18:30:49 DNSServer: -> DNS response from higher level
18:30:50 DNSServer: DNS request received!
18:30:50 DNSServer: Source: ('192.168.1.124', 56053)
18:30:50 DNSServer: Domain: p05-keyvalueservice.icloud.com
18:30:50 DNSServer: ***forward request
18:30:50 DNSServer: -> DNS response from higher level
18:30:53 DNSServer: DNS request received!
18:30:53 DNSServer: Source: ('192.168.1.124', 60240)
18:30:53 DNSServer: Domain: a3.mzstatic.com
18:30:53 DNSServer: ***forward request
18:30:53 DNSServer: -> DNS response from higher level
18:30:54 DNSServer: DNS request received!
18:30:54 DNSServer: Source: ('192.168.1.124', 53444)
18:30:54 DNSServer: Domain: a1.mzstatic.com
18:30:54 DNSServer: ***forward request
18:30:54 DNSServer: -> DNS response from higher level
18:30:54 DNSServer: Source: ('192.168.1.124', 55379)
18:30:54 DNSServer: Domain: a5.mzstatic.com
18:30:54 DNSServer: Source: ('192.168.1.124', 49756)
18:30:54 DNSServer: Domain: a2.mzstatic.com
18:30:57 DNSServer: DNS request received!
18:30:57 DNSServer: Source: ('192.168.1.124', 53160)
18:30:57 DNSServer: Domain: init-p01st.push.apple.com
18:30:57 DNSServer: ***forward request
18:30:57 DNSServer: -> DNS response from higher level
18:30:58 DNSServer: DNS request received!
18:30:58 DNSServer: Source: ('192.168.1.124', 54195)
18:30:58 DNSServer: Domain: 35-courier.push.apple.com
18:30:58 DNSServer: ***forward request
18:30:58 DNSServer: -> DNS response from higher level
18:31:28 DNSServer: DNS request received!
18:31:28 DNSServer: Source: ('192.168.1.124', 60469)
18:31:28 DNSServer: Domain: 27-courier.push.apple.com
18:31:28 DNSServer: ***forward request
18:31:28 DNSServer: -> DNS response from higher level
18:31:28 DNSServer: Source: ('192.168.1.124', 61427)
18:31:28 DNSServer: Domain: p05-keyvalueservice.icloud.com
18:31:31 DNSServer: DNS request received!
18:31:31 DNSServer: Source: ('192.168.1.124', 61427)
18:31:31 DNSServer: Domain: p05-keyvalueservice.icloud.com
18:31:31 DNSServer: ***forward request
18:31:31 DNSServer: -> DNS response from higher level
18:31:32 DNSServer: DNS request received!
18:31:32 DNSServer: Source: ('192.168.1.124', 51065)
18:31:32 DNSServer: Domain: itunes.apple.com
18:31:32 DNSServer: ***forward request
18:31:32 DNSServer: -> DNS response from higher level
Any suggestions or hints?
I just restarted both my computer and apple TV3. Seems to be running much smoother now, not as much lag at all; although still sometimes shows accessing trailers and spinning circle. However, now when I try to play anything, and I mean anything, it says "An error occurred loading this content. Try again later" ---> I can't play ANYTHING. Any suggestions? Really appreciate everything guys, so glad to see this "moving along" even slowly. Thanks
More info is needed on your setup along with a log, see the sticky for details.
Thanks f00b4r! I am going to mark this thread as solved and start a new one, containing all my info. Thanks again, please keep up the help!
