Trailers unavailable
Hi, im a novice computer user and have been trying to get get pled connect up and running on my apple tv3. i feel i have followed the instructions correctly, have added the certificates etc. but it just seems to hang on "accessing trailers" for ages only to finally say "trailers inaccessible" after a few minutes. please see details below. any advice etc would be greatly appreciated. thanks
Brett
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): apple tv 3 6.1.1
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS):192.168.0.200
  • The local IP address of the device that PlexConnect is installed on:
    192.168.0.20
  • The device and operating system (including version number) that PlexConnect is installed on: macbook pro osx 10.9.2
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: macbook pro osx 10.9.2
  • The Plex media server (PMS) version number you are running (do not put 'latest’): 2.1.1.2
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.0.200
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork.
    27 may 2014 1.07 pm
  • The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
    Last login: Tue Jun  3 19:06:57 on ttys000
    Bretts-MacBook-Pro:~ brettwabbis$ sudo "/Applications/PlexConnect-master/PlexConnect.py"
    Password:
    Sorry, try again.
    Password:
    20:57:24 PlexConnect: ***
    20:57:24 PlexConnect: PlexConnect
    20:57:24 PlexConnect: Press CTRL-C to shut down.
    20:57:24 PlexConnect: started: 20:57:24
    20:57:24 PlexConnect: Version: 0.3.1+
    20:57:24 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
    [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
    20:57:24 PlexConnect: Host OS: darwin
    20:57:24 PlexConnect: IP_self: 192.168.0.20
    20:57:24 DNSServer: started: 20:57:24
    20:57:24 DNSServer: ***
    20:57:24 DNSServer: DNSServer: Serving DNS on 192.168.0.20 port 53.
    20:57:24 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.20
    20:57:24 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
    20:57:24 DNSServer: forward other to higher level DNS: 8.8.8.8
    20:57:24 WebServer: started: 20:57:24
    20:57:24 WebServer: ***
    20:57:24 WebServer: WebServer: Serving HTTP on 192.168.0.20 port 80.
    20:57:24 WebServer: WebServer: Serving HTTPS on 192.168.0.20 port 443.
    ^C20:57:53 PlexConnect: Shutting down.
    20:57:53 WebServer: Shutting down.
    20:57:54 DNSServer: Shutting down.
    20:57:54 PlexConnect: shutdown
  • Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this tohttp://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):
  • A detailed description of the issue HI I’m new to plex, just been trying to set it up with apple tv 3. i feel like i have done all steps correctly but when i click on trailers it just says “accessing trailer” for ages and finally comes up with “trailers is unavailable, try again later."
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
    • shutdown PlexConnect
    • in 'Settings.cfg', set loglevel to "High"
    • delete the existing log file
    • restart PlexConnect
    • repeat the issue
    • immediately close PlexConnect and post the log.
    • in 'Settings.cfg', set the loglevel back to “Normal”
© 2013 PlexConnect Team
you configured .200 in the ATV, but have it running on .20.  Is that a typo?
no that is how i put it in, i assumed that on the atv i would just put an extra  "0" because there didn't seem to be a way to just have it .20
Have a made a simple error here?
My apple tv reads. 192.168.000.200
then that is your issue, it should read .020
thanks for such prompt responses bob snot, i thought that may have fixed it since i saw some lines of code change on the terminal screen, but now when i go into trailers, straight away it just comes up with "trailers in unavailable. try again later." please see below for my terminal screen. when i clicked the trailers on apple i noticed "intercept request" etc. come up. Any ideas? Once again thanks for your time
Last login: Tue Jun  3 20:54:44 on ttys000
Bretts-MacBook-Pro:~ brettwabbis$ openssl req -new -nodes -newkey rsa:2048 -out ~/Desktop/trailers.pem -keyout ~/Desktop/trailers.key -x509 -days 7300 -subj "/C=US/CN=trailers.apple.com"
Generating a 2048 bit RSA private key
unable to write 'random state'
writing new private key to '/Users/brettwabbis/Desktop/trailers.key'
Bretts-MacBook-Pro:~ brettwabbis$ openssl x509 -in ~/Desktop/trailers.pem -outform der -out ~/Desktop/trailers.cer && cat ~/Desktop/trailers.key >> ~/Desktop/trailers.pem
Bretts-MacBook-Pro:~ brettwabbis$  C:\OpenSSL-Win32\bin\openssl.exe x509 -in C: railers.pem -outform der -out C: railers.der
-bash: C:OpenSSL-Win32binopenssl.exe: command not found
Bretts-MacBook-Pro:~ brettwabbis$ sudo ./PlexConnect.py
Password:
sudo: ./PlexConnect.py: command not found
21:57:32 PlexConnect: ***
21:57:32 PlexConnect: PlexConnect
21:57:32 PlexConnect: Press CTRL-C to shut down.
21:57:32 PlexConnect: started: 21:57:32
21:57:32 PlexConnect: Version: 0.3.1+
21:57:32 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
21:57:32 PlexConnect: Host OS: darwin
21:57:32 PlexConnect: IP_self: 192.168.0.20
21:57:32 DNSServer: started: 21:57:32
21:57:32 DNSServer: ***
21:57:32 DNSServer: DNSServer: Serving DNS on 192.168.0.20 port 53.
21:57:32 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.20
21:57:32 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:57:32 DNSServer: forward other to higher level DNS: 8.8.8.8
21:57:33 WebServer: started: 21:57:33
21:57:33 WebServer: ***
21:57:33 WebServer: WebServer: Serving HTTP on 192.168.0.20 port 80.
21:57:33 WebServer: WebServer: Serving HTTPS on 192.168.0.20 port 443.
22:20:04 DNSServer: DNS request received!
22:20:04 DNSServer: Source: ('192.168.0.11', 49195)
22:20:04 DNSServer: Domain: www.apple.com
22:20:04 DNSServer: ***forward request
22:20:05 DNSServer: -> DNS response from higher level
22:20:13 DNSServer: DNS request received!
22:20:13 DNSServer: Source: ('192.168.0.11', 62769)
22:20:13 DNSServer: Domain: p71-buy.itunes.apple.com
22:20:13 DNSServer: ***forward request
22:20:13 DNSServer: -> DNS response from higher level
22:20:14 DNSServer: DNS request received!
22:20:14 DNSServer: Source: ('192.168.0.11', 50422)
22:20:14 DNSServer: Domain: EVIntl-ocsp.verisign.com
22:20:14 DNSServer: ***forward request
22:20:14 DNSServer: -> DNS response from higher level
22:20:19 DNSServer: DNS request received!
22:20:19 DNSServer: Source: ('192.168.0.11', 64010)
22:20:19 DNSServer: Domain: trailers.apple.com
22:20:19 DNSServer: ***intercept request
22:20:19 DNSServer: -> DNS response: 192.168.0.20
22:22:00 DNSServer: DNS request received!
22:22:00 DNSServer: Source: ('192.168.0.11', 61886)
22:22:00 DNSServer: Domain: trailers.apple.com
22:22:00 DNSServer: ***intercept request
22:22:00 DNSServer: -> DNS response: 192.168.0.20
22:22:03 DNSServer: DNS request received!
22:22:03 DNSServer: Source: ('192.168.0.11', 55140)
22:22:03 DNSServer: Domain: se.itunes.apple.com
22:22:03 DNSServer: ***forward request
22:22:03 DNSServer: -> DNS response from higher level
22:22:03 DNSServer: Source: ('192.168.0.11', 50761)
22:22:03 DNSServer: Domain: itunes.apple.com
22:22:04 DNSServer: DNS request received!
22:22:04 DNSServer: Source: ('192.168.0.11', 64834)
22:22:04 DNSServer: Domain: a4.mzstatic.com
22:22:04 DNSServer: ***forward request
22:22:05 DNSServer: -> DNS response from higher level
22:22:05 DNSServer: DNS request received!
22:22:05 DNSServer: Source: ('192.168.0.11', 59550)
22:22:05 DNSServer: Domain: a2.mzstatic.com
22:22:05 DNSServer: ***forward request
22:22:05 DNSServer: Source: ('192.168.0.11', 54821)
22:22:05 DNSServer: Domain: a3.mzstatic.com
22:22:06 DNSServer: -> DNS response from higher level
22:22:06 DNSServer: DNS request received!
22:22:06 DNSServer: Source: ('192.168.0.11', 61980)
22:22:06 DNSServer: Domain: a5.mzstatic.com
22:22:06 DNSServer: ***forward request
22:22:06 DNSServer: Source: ('192.168.0.11', 57305)
22:22:06 DNSServer: Domain: a1.mzstatic.com
22:23:21 DNSServer: DNS request received!
22:23:21 DNSServer: Source: ('192.168.0.11', 57352)
22:23:21 DNSServer: Domain: init-p01st.push.apple.com
22:23:21 DNSServer: ***forward request
22:23:21 DNSServer: -> DNS response from higher level
22:23:21 DNSServer: Source: ('192.168.0.11', 50102)
22:23:21 DNSServer: Domain: 29-courier.push.apple.com
22:23:22 DNSServer: -> DNS response from higher level
22:23:22 DNSServer: DNS request received!
22:23:22 DNSServer: Source: ('192.168.0.11', 54518)
22:23:22 DNSServer: Domain: www.isg-apple.com.akadns.net
22:23:22 DNSServer: ***forward request
^C22:24:30 PlexConnect: Shutting down.
22:24:30 WebServer: Shutting down.
22:24:32 DNSServer: Shutting down.
22:24:32 PlexConnect: shutdown
Password:
22:24:52 PlexConnect: ***
22:24:52 PlexConnect: PlexConnect
22:24:52 PlexConnect: Press CTRL-C to shut down.
22:24:52 PlexConnect: started: 22:24:52
22:24:52 PlexConnect: Version: 0.3.1+
22:24:52 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
22:24:52 PlexConnect: Host OS: darwin
22:24:52 PlexConnect: IP_self: 192.168.0.20
22:24:52 DNSServer: started: 22:24:52
22:24:52 DNSServer: ***
22:24:52 DNSServer: DNSServer: Serving DNS on 192.168.0.20 port 53.
22:24:52 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.20
22:24:52 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:24:52 DNSServer: forward other to higher level DNS: 8.8.8.8
22:24:52 WebServer: started: 22:24:52
22:24:52 WebServer: ***
22:24:52 WebServer: WebServer: Serving HTTP on 192.168.0.20 port 80.
22:24:52 WebServer: WebServer: Serving HTTPS on 192.168.0.20 port 443.
22:25:03 DNSServer: DNS request received!
22:25:03 DNSServer: Source: ('192.168.0.11', 59583)
22:25:03 DNSServer: Domain: trailers.apple.com
22:25:03 DNSServer: ***intercept request
22:25:03 DNSServer: -> DNS response: 192.168.0.20
start with re-reading and following this
Hi, I just redid those steps and tried again to no avail. Im sorry if I've missed something easy or changed something around?
Same thing us before, accessing trailers hangs for a while and then comes up with trailers unavailable. Does that all look ok?
Last login: Tue Jun  3 21:05:22 on ttys000
Password:
22:39:02 PlexConnect: ***
22:39:02 PlexConnect: PlexConnect
22:39:02 PlexConnect: Press CTRL-C to shut down.
22:39:02 PlexConnect: started: 22:39:02
22:39:02 PlexConnect: Version: 0.3.1+
22:39:02 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
22:39:02 PlexConnect: Host OS: darwin
22:39:02 PlexConnect: IP_self: 192.168.0.20
22:39:02 DNSServer: started: 22:39:02
22:39:02 DNSServer: ***
22:39:02 DNSServer: DNSServer: Serving DNS on 192.168.0.20 port 53.
22:39:02 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.20
22:39:02 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:39:02 DNSServer: forward other to higher level DNS: 8.8.8.8
22:39:02 WebServer: started: 22:39:02
22:39:02 WebServer: ***
22:39:02 WebServer: WebServer: Serving HTTP on 192.168.0.20 port 80.
22:39:02 WebServer: WebServer: Serving HTTPS on 192.168.0.20 port 443.
how about the step where you copy the cert files to a specific directory?
i have the .pem and .per in the following directory. is that correct?
/Applications/PlexConnect-master/assets/certificates
Password:
22:45:57 DNSServer: DNS request received!
22:45:57 DNSServer: Source: ('192.168.0.11', 62957)
22:45:57 DNSServer: Domain: init-p01st.push.apple.com
22:45:57 DNSServer: ***forward request
22:45:57 DNSServer: -> DNS response from higher level
22:45:57 DNSServer: Source: ('192.168.0.11', 57522)
22:45:57 DNSServer: Domain: 49-courier.push.apple.com
22:45:57 DNSServer: Source: ('192.168.0.11', 57196)
22:45:57 DNSServer: Domain: www.apple.com
22:45:58 DNSServer: -> DNS response from higher level
22:46:00 DNSServer: DNS request received!
22:46:00 DNSServer: Source: ('192.168.0.11', 61938)
22:46:00 DNSServer: Domain: p71-buy.itunes.apple.com
22:46:00 DNSServer: ***forward request
22:46:00 DNSServer: -> DNS response from higher level
22:46:07 DNSServer: DNS request received!
22:46:07 DNSServer: Source: ('192.168.0.11', 52631)
22:46:07 DNSServer: Domain: trailers.apple.com
22:46:07 DNSServer: ***intercept request
22:46:07 DNSServer: -> DNS response: 192.168.0.20
22:48:33 DNSServer: DNS request received!
22:48:33 DNSServer: Source: ('192.168.0.11', 59874)
22:48:33 DNSServer: Domain: trailers.apple.com
22:48:33 DNSServer: ***intercept request
22:48:33 DNSServer: -> DNS response: 192.168.0.20
22:49:57 DNSServer: DNS request received!
22:49:57 DNSServer: Source: ('192.168.0.11', 54610)
22:49:57 DNSServer: Domain: www.apple.com
22:49:57 DNSServer: ***forward request
22:49:57 DNSServer: -> DNS response from higher level
22:50:12 DNSServer: DNS request received!
22:50:12 DNSServer: Source: ('192.168.0.11', 51792)
22:50:12 DNSServer: Domain: trailers.apple.com
22:50:12 DNSServer: ***intercept request
22:50:12 DNSServer: -> DNS response: 192.168.0.20
22:50:45 DNSServer: DNS request received!
22:50:45 DNSServer: Source: ('192.168.0.11', 52274)
22:50:45 DNSServer: Domain: se.itunes.apple.com
22:50:45 DNSServer: ***forward request
22:50:45 DNSServer: -> DNS response from higher level
22:50:46 DNSServer: DNS request received!
22:50:46 DNSServer: Source: ('192.168.0.11', 51625)
22:50:46 DNSServer: Domain: pd-nk.itunes.apple.com
22:50:46 DNSServer: ***forward request
22:50:46 DNSServer: -> DNS response from higher level
22:50:47 DNSServer: DNS request received!
22:50:47 DNSServer: Source: ('192.168.0.11', 62160)
22:50:47 DNSServer: Domain: a2.mzstatic.com
22:50:47 DNSServer: ***forward request
22:50:47 DNSServer: -> DNS response from higher level
22:50:47 DNSServer: Source: ('192.168.0.11', 63161)
22:50:47 DNSServer: Domain: a3.mzstatic.com
22:50:47 DNSServer: Source: ('192.168.0.11', 62997)
22:50:47 DNSServer: Domain: a5.mzstatic.com
22:50:48 DNSServer: -> DNS response from higher level
22:50:48 DNSServer: DNS request received!
22:50:48 DNSServer: Source: ('192.168.0.11', 55293)
22:50:48 DNSServer: Domain: EVIntl-ocsp.verisign.com
22:50:48 DNSServer: ***forward request
22:50:49 DNSServer: DNS request received!
22:50:49 DNSServer: Source: ('192.168.0.11', 55731)
22:50:49 DNSServer: Domain: a1218.phobos.apple.com
22:50:49 DNSServer: ***forward request
22:50:49 DNSServer: -> DNS response from higher level
22:50:49 DNSServer: Source: ('192.168.0.11', 49425)
22:50:49 DNSServer: Domain: www.google.com
22:50:49 DNSServer: Source: ('192.168.0.11', 56634)
22:50:49 DNSServer: Domain: configuration.apple.com
22:50:50 DNSServer: DNS request received!
22:50:50 DNSServer: Source: ('192.168.0.11', 55149)
22:50:50 DNSServer: Domain: sr.symcd.com
22:50:50 DNSServer: ***forward request
22:50:50 DNSServer: -> DNS response from higher level
attach your Settings.cfg file.
hi can i ask i probably stupid question. How do i attach that file? i just died and it says I'm not permitted to attach that kind of file?
tried**^
>> tried**^
Hey... there is an "Edit" link in each post. :-)
>> attach...
Yep, Plex forum prevents a couple of file types from being attached. The settings.cfg file is easily copied into the post, the log file (as in physical file on your hard drive, not the just the terminal output) better attached, or provided using paste bin or similar.
>> certs
You shouldn't create a new Cert each time before you start PlexConnect and think your aTV would be able to get in contact... aTV needs to have the correct key - and needs a new one if you rebuild the lock.
From your aTV, remove all installed trailer certs, then install the last one generated - easiest to do following the link provided.
And then I have no idea what "unable to write 'random state'" is supposed to mean...
hi, i fixed it! I deleted profiles on both devices, regenerated and then installed the certificates. Then went to add profiles to the apple tv and realised i had put in my ip address( as  "http://trailers.apple.com/trailers.cer" didn't seem to work unless i put my ip address in also) but i had typed in .20 not .02  ..   now it works perfectly. it seems that that .02 is what was the problem all along and probably when it wasn't working i tried to redo steps etc not realising i probably mucked the certificates up.  Thankyou for all your help, greatly appreciated. can i ask one more question, if i run the script run pled connect as launch demon, does that mean that i will not have to start it manually each time i turn on the computer? is there  any problem in doing this even if i may not be using pled connect at that time? excuse my ignorance lol
thanks again, I'm so rapt now!
I can't get it to work.
I installed everything, software, certificates. The log shows the interception, though ATV3 still says: Not available, try again later (very quick actually, almost instant...)
22:04:02 PlexConnect: started: 22:04:02
22:04:02 PlexConnect: Version: 0.4-dev
22:04:02 PlexConnect: Python: 2.7 (r27:82500, Aug 21 2010, 10:10:43)
[GCC 4.2.3]
22:04:02 PlexConnect: Host OS: linux2
22:04:02 Settings: getsetting enable_plexconnect_autodetect=False
22:04:02 Settings: getsetting ip_plexconnect=192.168.1.7
22:04:02 PlexConnect: IP_self (from settings): 192.168.1.7
22:04:02 Settings: getsetting hosttointercept=trailers.apple.com
22:04:02 ATVSettings: init class CATVSettings
22:04:02 ATVSettings: load settings
22:04:02 Settings: getsetting enable_dnsserver=True
22:04:02 DNSServer: started: 22:04:02
22:04:02 Settings: getsetting port_dnsserver=53
22:04:02 Settings: getsetting ip_dnsmaster=8.8.8.8
22:04:02 Settings: getsetting prevent_atv_update=True
22:04:02 DNSServer: ***
22:04:02 DNSServer: DNSServer: Serving DNS on 192.168.1.7 port 53.
22:04:02 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.7
22:04:02 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:04:02 DNSServer: forward other to higher level DNS: 8.8.8.8
22:04:02 WebServer: started: 22:04:02
22:04:02 Settings: getsetting port_webserver=80
22:04:02 WebServer: ***
22:04:02 WebServer: WebServer: Serving HTTP on 192.168.1.7 port 80.
22:04:02 Settings: getsetting enable_webserver_ssl=True
22:04:02 Settings: getsetting port_ssl=443
22:04:02 Settings: getsetting certfile=./assets/certificates/trailers.pem
22:04:02 WebServer: WebServer: Serving HTTPS on 192.168.1.7 port 443.
22:05:31 DNSServer: DNS request received!
22:05:31 DNSServer: Source: ('192.168.1.5', 62635)
22:05:31 DNSServer: Domain: www.apple.com
22:05:31 DNSServer: ***forward request
22:05:31 DNSServer: -> DNS response from higher level
22:05:31 DNSServer: Source: ('192.168.1.5', 52207)
22:05:31 DNSServer: Domain: apple.com
22:05:31 DNSServer: Source: ('192.168.1.5', 63773)
22:05:31 DNSServer: Domain: local
22:05:31 DNSServer: Source: ('192.168.1.5', 54639)
22:05:31 DNSServer: Domain: init-p01st.push.apple.com
22:05:31 DNSServer: Source: ('192.168.1.5', 50061)
22:05:31 DNSServer: Domain: 11-courier.push.apple.com
22:05:34 DNSServer: DNS request received!
22:05:34 DNSServer: Source: ('192.168.1.5', 58318)
22:05:34 DNSServer: Domain: itunes.apple.com
22:05:34 DNSServer: ***forward request
22:05:34 DNSServer: -> DNS response from higher level
22:05:40 DNSServer: DNS request received!
22:05:40 DNSServer: Source: ('192.168.1.5', 63182)
22:05:40 DNSServer: Domain: trailers.apple.com
22:05:40 DNSServer: ***intercept request
22:05:40 DNSServer: -> DNS response: 192.168.1.7
22:05:45 DNSServer: DNS request received!
22:05:45 DNSServer: Source: ('192.168.1.5', 57457)
22:05:45 DNSServer: Domain: a5.mzstatic.com
22:05:45 DNSServer: ***forward request
22:05:46 DNSServer: -> DNS response from higher level
22:07:48 PlexConnect: Shutting down.
22:07:48 WebServer: Shutting down (HTTPS).
22:07:49 WebServer: Shutting down (HTTP).
22:07:52 DNSServer: Shutting down.
22:07:52 ATVSettings: save settings
22:07:52 PlexConnect: shutdown
Please help... thanks in advance!
[GCC 4.2.3]
Trailers unavailable us the generic apple error. Please follow the pinned "Read Before Posting" thread, specifically the section on how to report a problem, and then start a new thread with the template and attach a log file with logging set to High as this will contain a lot more debug information
