Please help with LiveTV on Amazon FireTV stick
Server Version#: 1.20.1.3252 (Qnap NAS)
Player Version#: Amazon FireTV stick 8.6.0.20351
Tuner Make/Model: HDHomerun Connect DUO
My Server Version is 1.20.1.3252 and it is run on a QNAP NAS.
Player Version#: 8.6.0.20351
Tuner Make/Model: HDHomeRun DUO
I can’t get LiveTV to work on my Amazon FireTV stick, but it works on my Android Phone and web browser? I just purchased a second FireTV because I couldn’t get it to work on my older one and I thought that the problem might be that my FireTV stick was too old. I tried everything I can think of. I cleared cache on the App and also removed it and re-installed it with no luck. When I go to the LiveTV/DVR selection it says “No Items to Display”. I don’t even get the guide.
I downloaded the Logs under “Trouble Shooting”, but there are so many and they are in XML format so I don’t have any idea which one to look in or what I am looking for. Can someone please help?
Thanks,
Jim
I get this error in my Plex Console when I switch the Plex App on the FireTV stick to LiveTV:
Interesting discovery: On my Android Phone (Which works) I get this in console (The port number is different):
I Pulled this from the logfile on the AmazonTV Stick after switching to LiveTV/DVR:
09-25 01:29:21.509 i: [LiveAiringMediaItemsMonitor] Cancelling change detection
09-25 01:29:21.735 e: Error fetching https://71-168-114-117.0b1af7ac54f847c6b319e4a6eafab888.plex.direct:25912/hubs/sections/discover?count=20&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=0&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...tml>
09-25 01:29:21.750 i: [LiveAiringMediaItemsMonitor] Cancelling change detection
09-25 01:29:21.769 i: [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours.
09-25 01:29:21.775 i: [LiveAiringMediaItemsMonitor] Cancelling change detection
