Please please please fix the caption issue
Server Version#: 1.41.0.8994
Player Version#: 1.102.0.230-7301ebfb, 10.22.0.1579 (6a8017c9)
Tuner Make/Model: HDHomerun Prime
TLDR: captions are broken for sub accounts on Windows, Android, and Linux.
Problem experienced on Windows and Linux: Click a channel from the guide, it plays with captions showing. Click settings. Settings show captions are turned off so why are there captions? To turn captions off, I must first turn the setting to on (which changes nothing), then I can select none to get them to turn off. Annoying, but not a huge issue.
Problem experienced on Android: Click a channel from the guide, get a permanent black screen and can’t watch TV. On a TV interface device like Nvidia Shield, enabling captions gets the channel playing with captions. Turning captions back off, the channel will continue working without captions. On a phone you are sheet out of luck because there is no dedicated caption button on that interface and you can’t get to settings because the video never loads. I have tried setting my phone app to the TV interface, used a Bluetooth mouse to navigate, and can confirm it’s the same behavior on the phone as the shield. Who is going to carry a mouse with them just to watch TV on their phone though? Live TV on Android phones should be considered completely broken. Just a black screen.
To further confirm the Android black screen issue is captions related… If I start watching a channel on Windows or Linux, turn caption setting on the Windows/Linux client to on then to off, then play the same channel on Android, the channel now plays on Android without issue like it should. If I don’t kill the captions on another device first, Android sees that it’s being played on another device because it asks if I want to play it live, but it still goes to the black screen.
Problem experienced on iOS: None! Only device where captions work properly.
Solutions tried: Restarting everything. Uninstalling and reinstalling everything. Made sure everything is up to date. Tried many different software versions on many different OS versions considering this problem has existed for 15+ months now. I’ve tried pointing out this issue in multiple forum posts and have uploaded logs in those threads, but mods just ignore me and the issue. Is creating a new thread the answer? Guess I’ll find out…
Attaching a screenshot showing the odd behavior, and logs from the server, two android clients, and a windows client.
Logs.zip (110.8 KB)
LOL Lots of LUCK! LOL My Samsung Phone using Plex with HDhome run plays in Spanish! when it is set to EngRish the fix must switch to Spanish and back to EngRish to work! Known Issue for EVER!
