Plex 1.16.1.1246 DVR fails to schedule recordings
Server Version 1.16.1.1246:
I installed the update und reinitialized my DVR from the scratch, and also all my recordings. Now, if I choose certain TV Shows for example from the EPG or by searching the EPG, the DVR won’t ad the recording(s) to the schedule. This is only for some shows. I can’t recognize a system: Some HD-Shows oder SD-shows work, some not. Some Shows from one channel work, some form the same channel not. Changing recording preferences for that show doesn’t change anything.
@realjulian I had this issue and “fixed” it by selecting “new and repeat airings”, and not selecting HD only as nothing in my new EPG is marked HD.
No, that does not help. It‘s not a missing „new“ flag, not „HD only“ chosen, not the wrong channel or starting time. The recordings should work. And it started with the Update.
It may have to do with a new structure to manage the EPG. I have now found a way to record this programme. It is a news show that also runs on several channels and I only want to record a certain edition daily. Until the last updated this was managed differently when creating recordings. It worked now finally, when I had selected a certain transmission at a certain time on a certain channel.
I have the same problem and it started with the new EPG upgrade too.
I managed to schedule 1 of my daily shows now. Another show still won’t. I had it scheduled but when I changed “add to library” it disappeared. Now it is impossible to schedule this again.
