PLEX 64-bit install on Syno DS 415+ dont work
i try to install PlexMediaServer-1.12.3.4973-215c28d86-x86_64 on my Syno DS 415+, DSM ist aktuell.
When i Try to install it will seems to start install, after 15 minutes there ist noc change in the Message there stand only " Verarbeitung läuft"
Maybe someone can give me an advise?
Thx Kaz
Kazad,
Did you attempt to open first time using http://ip.addr.of.syno:32400/web ?
If Yes then:
  1. Open Control Panel - Shared Folders. Add R/W permission to your username for the Plex share.
  2. Open File Station -> Plex / Library / Application Support / Plex Media Server
  3. Delete Preferences.xml
  4. Right-click Logs. Compress to Logs.zip
  5. Attach the ZIP file with your next post.
What is the LAN IP of your Synology? What is the IP address of your computer?
    done
    done
    done
    192.168.178.12 NAS
    192.168.178.60 PC
Kazad,
Your log files are confusing:
Plex Media Server.1.log , the previous log stops with 31-Mar-2016
Mar 31, 2016 19:43:03 [0xf1911b70] DEBUG - Completed: [127.0.0.1:36450] GET /:/metadata/updateProgressMessage?message=Scanning%20P%20-%20R%2FPlanet%2051 (2 live) GZIP 1ms 129 bytes 200
Mar 31, 2016 19:43:03 [0xeabffb70] DEBUG - Request: [127.0.0.1:36451] GET /:/metadata/updateProgressMessage?message=Scanning%20P%20-%20R%2FPlan%20B%20fuer%20die%20Liebe (2 live) GZIP
Mar 31, 2016 19:43:03 [0xf1911b70] DEBUG - Completed: [127.0.0.1:36451] GET /:/metadata/updateProgressMessage?message=Scanning%20P%20-%20R%2FPlan%20B%20fuer%20die%20Liebe (2 live) GZIP 1ms 129 bytes 200
Mar 31, 2016 19:43:03 [0xefbffb70] DEBUG - Request: [127.0.0.1:36452] GET /:/metadata/updateProgressMessage?message=Scanning%20P%20-%20R%2FPizza%20Pizza%20-%20Ein%20St%C3%BCck%20Vom%20Himmel (2 live) GZIP
Mar 31, 2016 19:43:03 [0xf1bffb70] DEBUG - Completed: [127.0.0.1:36452] GET /:/metadata/updateProgressMessage?message=Scanning%20P%20-%20R%2FPizza%20Pizza%20-%20Ein%20St%C3%BCck%20Vom%20Himmel (2 live) GZIP 1ms 129 bytes 200
While the current log file, and only one for 2018, began 08-May-2018 02.37h
May 08, 2018 02:37:23.101 [0x7f4ea9656700] INFO - Plex Media Server v1.12.3.4973-215c28d86 - ubuntu PC x86_64 - build: linux-ubuntu-x86_64 synology - GMT 02:00
May 08, 2018 02:37:23.118 [0x7f4ea9656700] INFO - Linux version: 3.10.102 (#15266 SMP Mon Mar 26 15:08:28 CST 2018), language: en-US
May 08, 2018 02:37:23.118 [0x7f4ea9656700] INFO - Processor         Intel(R) Atom(TM) CPU  C2538  @ 2.40GHz
May 08, 2018 02:37:23.118 [0x7f4ea9656700] INFO - /var/packages/Plex Media Server/target/Plex Media Server
May 08, 2018 02:37:23.084 [0x7f4ea9368700] DEBUG - EventSource: Got event [data] '<Message address="84.138.241.192" port="32400" asyncIdentifier="b7dc0721-fdd1-4c8a-a2a2-dc56d54922b8" connectivity="0" command="notifyConnectivity"/>'
Where are the missing log segments from earlier AND,
II do not see any error.
I see authorized connection to PMS,
May 08, 2018 02:58:41.142 [0x7f4ea1223700] DEBUG - Setting container serialization range to [0, 11] (total=-1)
May 08, 2018 02:58:41.143 [0x7f4ea7fff700] DEBUG - Completed: [192.168.178.60:52874] 200 GET /hubs/home/continueWatching (11 live) GZIP Page 0-11 101ms 480 bytes (pipelined: 16)
May 08, 2018 02:58:41.146 [0x7f4e91a6b700] DEBUG - Request: [192.168.178.60:52874 (Allowed Network)] GET /hubs/home/recentlyAdded?type=1&personal=1 (10 live) Page 0-11 GZIP Signed-in
May 08, 2018 02:58:41.148 [0x7f4e91a6b700] DEBUG - Setting container serialization range to [0, 11] (total=-1)
May 08, 2018 02:58:41.149 [0x7f4e92047700] DEBUG - Setting container serialization range to [0, 11] (total=-1)
May 08, 2018 02:58:41.149 [0x7f4ea7d11700] DEBUG - Completed: [192.168.178.60:52874] 200 GET /hubs/home/recentlyAdded?type=1&personal=1 (10 live) GZIP Page 0-11 3ms 480 bytes (pipelined: 17)
May 08, 2018 02:58:41.151 [0x7f4ea03ff700] DEBUG - It took 110.000000 ms to retrieve 39 items.
May 08, 2018 02:58:41.152 [0x7f4e8c047700] DEBUG - Request: [192.168.178.60:52874 (Allowed Network)] GET /hubs/home/recentlyAdded?type=13 (9 live) Page 0-11 GZIP Signed-in
I see playback sessions to FireFox as well as system processing (02.00h Scheduled Tasks)
May 08, 2018 02:37:23.306 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47078] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20gef%C3%BCrchteten%20Vier%20(1966) (22 live) GZIP 0ms 166 bytes
May 08, 2018 02:37:23.314 [0x7f4ea0f35700] DEBUG - Request: [127.0.0.1:47079 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20letzte%20Festung%20(2001) (22 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.315 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47079] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20letzte%20Festung%20(2001) (22 live) GZIP 1ms 166 bytes
May 08, 2018 02:37:23.324 [0x7f4e9bf35700] DEBUG - Request: [127.0.0.1:47080 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20gro%C3%9Fe%20Versuchung%20-%20L%C3%BCgen%2C%20bis%20der%20Arzt%20kommt%20(2014) (23 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.324 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47080] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20gro%C3%9Fe%20Versuchung%20-%20L%C3%BCgen%2C%20bis%20der%20Arzt%20kommt%20(2014) (22 live) GZIP 1ms 166 bytes
May 08, 2018 02:37:23.327 [0x7f4e8ba6b700] DEBUG - Request: [127.0.0.1:47081 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20ins%20Gras%20bei%C3%9Fen%20(1962) (23 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.328 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47081] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20ins%20Gras%20bei%C3%9Fen%20(1962) (22 live) GZIP 1ms 166 bytes
May 08, 2018 02:37:23.337 [0x7f4e8c623700] DEBUG - Request: [127.0.0.1:47082 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20Wiege%20der%20Sonne%20(1993) (22 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.338 [0x7f4ea7fff700] DEBUG - Completed: [127.0.0.1:47082] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20Wiege%20der%20Sonne%20(1993) (22 live) GZIP 1ms 166 bytes
May 08, 2018 02:37:23.341 [0x7f4e9f559700] DEBUG - Request: [127.0.0.1:47083 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20f%C3%BCnf%20Gef%C3%BCrchteten%20(1969) (22 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.341 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47083] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20f%C3%BCnf%20Gef%C3%BCrchteten%20(1969) (22 live) GZIP 0ms 166 bytes
May 08, 2018 02:37:23.345 [0x7f4e9fb35700] DEBUG - Request: [127.0.0.1:47084 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20letzte%20Legion%20(2007) (22 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.346 [0x7f4ea7fff700] DEBUG - Completed: [127.0.0.1:47084] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20letzte%20Legion%20(2007) (22 live) GZIP 1ms 166 bytes
May 08, 2018 02:37:23.348 [0x7f4ea1223700] DEBUG - Request: [127.0.0.1:47085 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20drei%20Tage%20des%20Condor%20(1975) (22 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.349 [0x7f4ea7fff700] DEBUG - Completed: [127.0.0.1:47085] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20drei%20Tage%20des%20Condor%20(1975) (22 live) GZIP 0ms 166 bytes
May 08, 2018 02:37:23.357 [0x7f4ea0f35700] DEBUG - Request: [127.0.0.1:47086 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20nackte%20Wahrheit%20(2009) (22 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.358 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47086] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20nackte%20Wahrheit%20(2009) (22 live) GZIP 1ms 166 bytes
May 08, 2018 02:37:23.360 [0x7f4e9bf35700] DEBUG - Request: [127.0.0.1:47087 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20drei%20Musketiere%20(1993) (23 live) GZIP Signed-in Token (Kazad)
May 08, 2018 02:37:23.361 [0x7f4ea7d11700] DEBUG - Completed: [127.0.0.1:47087] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20D%20-%20F%2FDie%20drei%20Musketiere%20(1993) (22 live) GZIP 1ms 166 bytes
Am I missing something? I do not understand what is ‘Processing’ and hung?
ok, i try to explain.
pl 32 bit iss/ was installed on the NAS
then i want to use/ test hardware transcoding
i try to install the 64 bit version
first uninstall 32bit, the restart the nas und try to install 64 bit installer.
dont work
Are you using DSM 6.0 or higher?
Hardware transcoding requires an active PlexPass to activate.
