Plex 9.1.0 not swtching to TV version on android box (android 9) (ugoos X3)
You must sign in to Plex beta in play store or you could find beta in this forum Android (mobile) beta release notes - #532 by sixones
I can confirm the latest beta 9.3.0 has fixed the issue
Yes !!! Working as a charm (so far :wink:).
Yes the latest beta version works! And magically the files that cannot be played with version 9.0 can now play flawlessly! And ff/rewind now works very smooth and fast too! I will test this version further and post any issues that may arise! Thanks Plex dev!!!
Im having exactly the same issue with Plex on Android tv… looping back to the selection box no matter which option I try. It appears that when selecting ā€œTVā€ option it has to reboot… which throws back the loop as it doesnt remember the selection… going to look for the Beta version on your advice… thanks @Gytissszzz
