When the power goes out the mac switches Volume_A2 to Volume_B2. The solution is to either unplug the drive from the router and replug in or if remote, reboot the router.
This last time, it looks fine. The Mac (Sierra) mounts the drive as Volume_A2 but when i look through Plex Libraries it only sees it as Volume_A2-3.
How do i get PMS to see it correctly?
I’ve powercycled the router, the mac and just PMS. It keeps adding the -3
I have not had to do this in a long while but if I recall you need to all apps like the server that would have access to that volume in their settings. ( same goes for apps like sonarr or sabnzb etc and don’t let them launch on start up)
If they are external USB or network drives physically unmount/disconnect them
restart computer
you might need to unmount in terminal but it has been so long I don’t want to tell you bad commands to do that.
Ah thank you. I needed the right terminology. Phantom volumes (ghost is what i searched and got them). Answer is here for future reference. https://discussions.apple.com/thread/3046184
I wouldn’t have found it without you. Struggled with it all afternoon. Thank you!
Terminal
open /Volumes
Eject one in use
Drag rest to trash
