Plex Alternatives?
Can anyone recommend a Windows (server) and Windows/Android alternative to Plex?
I give up. Plex worked great for many years with very little TLC required, then came the Plex Pass requirement and long line of troubles. Not much plays problem-free (lag every 20 seconds or “cpu not strong enough”). Played with every setting I can see and if I fix one thing locally I break something new remotely. Logs don’t show what the articles say they should, tech support seems to consist of “go find it yourself”, it takes a month to switch a subscription (lol). Apologies on the rant. It’s been a lot of hours trying to get this thing to do what it had been doing flawlessly for years. What a complete clown show Plex has turned into.
I completely get where you’re coming from. Plex support is quite poor, it is like pulling nails trying to get acknowledgement of bug reports let alone troubleshooting help for general streaming problems. And when people complain about overall direction issues or support quality they get ignored. Plex is by far the most expensive piece of software I’ve paid for, ever, with this level of troubleshooting and support problems. The vast majority of the support appears to be accomplished by unpaid forum moderators who are basically just users trying to help out. It is especially galling to experience this when Plex periodically posts excited, investor-focused PR about how the company is growing. I’ll also add that to my knowledge there was a round of layoffs at Plex recently so the company is probably even worse staffed than usual. It’s kind of bewildering.
The main alternatives to Plex are Jellyfin, Kodi, and Emby. They each have some strengths but unfortunately their weaknesses tend to be that they are more difficult to troubleshoot and support because they are made for power users. In a sense this is the worst thing – Plex is good enough to corner the market on commercial, user-friendly media server software, but not good enough that users feel happy. It really sucks, I hear you. I personally have tried Jellyfin and find it works a little better but is quite a bit harder to use. Kodi works better when you only have a single client and when the client is more powerful than the server, which is not your use case (I don’t think it supports mobile either). I have not tried Emby.
If you’re having CPU issues the most likely causes are either: (a) the CPU on the server is very, very low end; or (b) the client cannot support the video being played, which causes the server to “transcode” the video. This means the server has to work very hard to quickly assemble a version of the video that the client can play. The best way to diagnose this is to check the dashboard on the server while the playing is occurring. So play the video on one client, and then on the server itself or on another client, click the little icon that looks like a heartbeat and has a number 1 in the top of the client, then click dashboard.
This will tell you whether your client is “Direct Play”ing the video or “Transcoding” the video. If it is transcoding, and particularly if the video is 4K, you need a very very powerful CPU or you need GPU transcoding enabled and you need a powerful GPU.
You can see that for me playing this file, it’s a 1080p file of the file type HEVC Main 10, with AAC 5.1 audio, and the video, audio, and subtitle file are all direct play with no transcoding. If that’s what you see, the problem is something else. But if you see transcode, then that’s the most likely culprit.
Hopefully these steps at least help you try to narrow it down a little bit. It might also help to know what kind of CPU you have on your server and what your network setup is.
Surely you searched the forums for “Plex Alternatives” before wasting your time on this post, right? There are enough topics on this to keep you reading all day.
or maybe, just maybe, people looking to get a question answered to them directly and would like to get some personal rant off their chest in the process, could in fact ask the same question on a message board without getting a condescending answer?
If the system worked for years and now it doesn’t work well, have you tried reinstalling Windows and setting up Plex from scratch? While I use and actually even like Windows I’ve found at times that flattening the box may help when nothing else did.
If the server is dedicated hardware you could also try Linux, which is more performant and stable. If you have a spare hard drive, give it a shot… You might enjoy the change.
The way I see it, you’re already signing up for substantial work in switching to a new media server, but a Windows rebuild or a switch to Linux isn’t more work, and it may let you stay on Plex, the platform you know and seem to like – when it works.
Good luck with whatever you decide.
I honestly don’t see the point of asking the same question over and over again if it’s already been asked and answered. If they wanted to rant, then just post a rant. No passive aggressive question is required (not that I’m suggesting it was, this is in response to your specific framing).
Don’t come at me with some “maybe, just maybe” stuff. The question has been asked and answered numerous times. There is no point in asking it again.
These are support forums, not “I want to have a go at Plex” forums.
Apropos of nothing, have at me with your response. I won’t be here to see it. I don’t understand these forums any longer.
They used to be a place where folks came together to help and support each other. Now, they’re only a place to whine. So yes, my initial response may have been a bit harsh. But no harsher the RTFM.
So long, and thanks for all the fish. Six month self-imposed time out starting… now. See y’all in 2026. Maybe.
Thank you guys for the info, much appreciated. More difficult to use is definitely not what I’m after and I guess maybe I just need to prepare myself that time spent troubleshooting is the new norm.
Most (not all) of the issues are indeed with 4k and maybe my server isn’t up to that task. It’s a Xeon 3.50 ghz 4 core / 32 gb ram / Quadro K2200 / Win11 / WD Red Pro, direct attached with lots of space. I did read about Intel Quick Sync Video being a requirement and I don’t believe the Xeon’s have that. Frustrating though because everything seemed to be working near-flawless both local and remote for a long, long time. It only went sideways with the Plex Pass, so I’m not sure why the server is all of a sudden a problem. Before the Pass, if I got a little lag I could reduce quality and that was that. Now, quality changes don’t seem to make any difference.
2 responses to whine about whining. I guess some of us take attention wherever we can get it.
Kudos on the break, sounds like it’s needed. :+1:
Quick Sync is extremely helpful if you are transcoding, but you haven’t really explained the details of whatever problems you are seeing. Are files that used to work now not working? Are they new files? What are the details of the files and the clients and the network? There is a huge matrix to consider.
I am sure you can get some feedback here on these problems, but you will need to list complete details for a couple of repeatable cases.
If you are having problems Direct Playing 4k videos on your LAN then there is probably some kind of network problem. But, it could be a client issue too.
If you are transcoding 4k, or especially 4k HDR, then the server specs are very important and this is where QSV (or other GPU assist) can be a big benefit. But, you have a GPU that should be able to handle a couple of streams.
The timing of the Plex Pass change is likely coincidental. There certainly are not widespread problems such as yours, we would have seen more posts.
I feel your pain. Support is non existent from Plex, the forum police are irrational defenders of Plex. Plex devs are only interested in shiny new toys (to be fair this is all devs) and not fixing or stabilizing the feature set.
Fair points. Main issues…
  1. Lag on certain titles with one device in particular- a (Fire) TV both with the built in app and when using the latest 4k FireTV stick. Local network, wifi connection. The lag is every few seconds to every few minutes. I thought these were a mix of formats but now I’m second guessing myself. I’m not at home this week to do proper testing (kids are doing a little for me) but when I look through several titles I know it’s been happening on, they’re all 4k HEVC.
  2. Lag on certain 4k HEVC titles, any device, local or remote. Constant buffering every 5-30 seconds. I have 2 known-bad and 3 known-good in 4k HEVC and when I do a ‘Get Info’ on the 5 I don’t see anything that that jumps out as common between working vs. not.
All that said, it might now be fixed. I haven’t been able to reproduce either issue since the other day when I gave a value to the previously blank: Remote Access –> Internet Upload Speed. Does it make sense that setting would impact the local network as well as remote?
It is possible I changed something else. Throwing :poop: against the wall at this point. But for the most part I’ve been making a single change, restarting plex on the server, and testing. I believe that was the latest change.
Thanks again for the help, everyone. Apologies on the guesswork at some of this.
If one client has consistent problems then it seems most likely that the client is at fault – but server/LAN tuning could be a factor, sure. If it’s in the budget I would consider replacing that client with one of those $20 ONN Android boxes.
Because the second problem was universal it seems like a networking issue, like the LAN was not up to that bitrate… But, then it went away. The setting you changed seems very unlikely to be involved, but you could test this to find out for sure. If there was an issue where leaving that value unset caused perf problems that’s a juicy bug that is worth characterizing and reporting.
Plex is a complex system, and when you factor in the crazy matrix of server/client capabilities, plus what I think of as “the normal windows BS,” there are a lot of things that can go wrong.
If you have any other hardware you can deploy as a temporary extra server that could help you to figure out if you are seeing a client or server problem. Maybe you have a gaming PC, spin up the Plex server on that and see if your Fire 4k client still has the same issues. Or boot into Ubuntu and try it that way.
There is no reason not to try the competition but it may be the case that you are trading one problem for slightly different problems.
