I’m currently having issues with Dolby Vision playback on my TV.
| Complete name : | \CCCNas\Movies\A Bronx Tale UHD (1993).mp4 |
| Format : | MPEG-4 |
| Format profile : | Base Media / Version 2 |
| Codec ID : | mp42 (mp42/dby1/iso2/mp41) |
| File size : | 2.66 GiB |
| Duration : | 2 h 1 min |
| Overall bit rate : | 3 131 kb/s |
| Frame rate : | 23.976 FPS |
| Movie name : | A Bronx Tale |
| Recorded date : | 1993 |
| ID : | 1 |
| Format : | HEVC |
| Format/Info : | High Efficiency Video Coding |
| Format profile : | Main 10@L5.1@Main |
| HDR format : | SMPTE ST 2086, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / Dolby Vision, HDR10 compatible / SMPTE ST 2086, HDR10 compatible |
| Codec ID : | hvc1 |
| Codec ID/Info : | High Efficiency Video Coding |
| Bit rate : | 2 187 kb/s |
| Width : | 3 840 pixels |
| Height : | 2 076 pixels |
So the exact issue I’m having is the movie direct plays from the start with no issues at all. But if i pause the movie or try to play from where i left off i get the loading symbol continuously. If i do not pause the whole movie will play with no issues at all.
My plex server is run on my NAS and the only issues i have is with DV, HDR10 is fine.
Any tips on this without removing DV from my movies?
