Plex and Pi-Hole
Hi. I have Pi-Hole running on a Raspberry PI. I have my router’s primary DNS set to my Pi. When I do this my Plex media server is unhappy because it’s an unsecure connection. I clicked on “Allow unsecure connections” and nothing happens. How do I resolve this?
Looks like someone may have found a solution:
Thanks.
I’ve tried that previously.
Here’s what I’ve tried:
I’ve added the following to the /etc/dnsmasq.d01-pihole.conf :
EDIT SETTINGS
dns-forward-max=5096
min-cache-ttl=300
rebind-domain-ok=/plex.direct/
END EDIT
And then issuing the following command: pihole restartdns
And I’ve added the following to /etc/unbound/unbound.conf.d :
EDIT SETTINGS
private-domain: plex.direct
END EDIT
And then issuing the following command: sudo service unbound restart
I’ve also restarted Plexmediaservices on my Ubuntu server.
Any other hints or advice?
PS
The two websites I used to make these edits are:
[SOLVED] Plex secure connection not possible - #3 by Bjoure (same as backfields recommendation)
and
Need to get plex working with pihole - Help - Pi-hole Userspace
Thanks again.
