Is there a reason that having the Developer options enabled (Pixel 10 in my case) on Android prevents the Plex app from starting properly?
With Developer options enabled in Android, I only get the Plex splash screen, never get the login. If I turn it off I get the sign-in screen. I know some other Android apps that does not let you do things if Developer options are enabled.
I have a 10pro and it opens fine with developer options enabled.
There is certainly some possibly that there is some particular option within it that causes issues but I am not aware of anything intentionally done to restrict their use.
