PLEX Android TV layout- Channels
PLEX Android, currently 5.5.0 and have had the issue on previous versions… Several channels will not play while is is set in TV mode ("playback has stopped because the connection to the plex media server has been lost…) In another support thread it suggested to “force direct play” and it works like a charm on my phone… but not on my Box. Problem is in TV mode I do not have the option to force direct play, only check or uncheck to allow it… If I switch the box to mobile mode, select force direct play, it works perfectly and plays… so I know its not a problem with my network or hardware… In TV mode is their another setting that needs to be changed?
