Hi all,
I was wondering how to get my 3D MKV’s working with my Plex Samsung Smart TV app?
Side by side or top to bottom doesn’t give the right view.
It’s a Samsung ue48ju7000 with active 3D glasses.
Thanks.
Hi all,
Thanks.
From the manual found here:
Playing 3D content
The app supports Half SBS and Half TAB 3D content. The app switches automatically in 3D
mode when it detects 3D content but this works only if you name your files correctly. You
must include a “3D” tag in the filename.
● “HSBS”, “H-SBS” or “Half-SBS” for Side-By-Side content
● “HTAB”, “H-TAB”, “Half-TAB” or “HALF-OU” for top-and-bottom/over-under content.
This is not case sensitive. An example as filename would be:
Kung.Fu.Panda.2.2011.half-sbs.1080p.mkv or Kung.Fu.Panda.2.2011.H-SBS.1080p.mkv.
Alternatively you may add the movie to a collection with a name that includes the 3D tag.
This will be required if you want to view 3D content from a remote server.
