eb98jdb
1
Running the latest version of the app on Samsung Tizen tv. Was running the preview then switched to the main release when it came out.
The issue is it’s taking a good couple of minutes to load the app. Works fine once it’s loaded.
Tried uninstalling and reinstalling. Any other ideas?
I’m having exactly the same problem. Mine is a Series 9 TV.
I had to buy a Roku just to run Plex; the TV app is a pain to use.
I also have this issue. Extremely annoying
SE56
4
Change your TV DNS to 1.1.1.1
https://1.1.1.1/dns/
Tried setting the DNS as suggested. Doesn’t work
system
Closed
6
