Does this not work on an integrated gpu? I have plex arcade running no issues on another server with a dedicated gpu, and on this server I have plex running movies fine via Intel igpu, but it won’t run any games. Is this known?
Add the arcade-gaming tag to get arcade specific eyes on your post.
Additional details will help as well.
PMS version?
Windows / Mac?
There are restrictions. See FAQ for details.
- Headless?
- Running Plex as a service?
- Supported CPU?
Nahh I don’t care enough I already posted on the plex reddit and was told nobody cares about plex arcade and then I come here and am told I didn’t post it right??? If truly nobody cares and you have to format it correctly to get the 3 people who use plex arcade to see it. I don’t care. Il just cancel plex arcade. Seems like plex doesn’t care either.
you havent supplied any info as to what CPU you are using. IF its not supported by Parsec then it wont work, if it is then it may be an issue with config/platform. Wont work on *nix platform, has to be windows/mac for now.
If you need help then you need to help people diagnose the issue by supplying some basic info about your setup.
Sorry for my snark, just was annoyed earlierm
Specs are i7-8700K
16GB RAM 3200MHZ
EVERYTHING ON NVME M.2 SAMSUNG 970 PRO SSD
MOVIES WORK, GAMES DON’T ON MOBILE DEVICES. GAMES WORK ON PC’S THOUGH.
what mobile devices are you trying to use? i know that there are some issues on ios, doesnt work on remote, only local lan for ios
Funny that Parsec haven’t updated their F.A.Q when Intel released their 11th gen CPU.
And frankly, Plex Arcade on 11th gen Intel CPU is unplayable due to massive frameskipping / stutters, but that might be linked to Parsec not supporting the 11th gen Tiger Lake CPU yet
