Plex attempting to connect to a device that does not exist
Server Version#: 1.18.2.2058
In Server logs, I get this fairly regularly:
Nov 26, 2019 19:57:14.712 [0x7f355599a700] ERROR - Error issuing curl_easy_perform(handle): 7
Nov 26, 2019 19:57:14.712 [0x7f355599a700] WARN - HTTP error requesting GET http://192.168.1.250:49152/wps_device.xml (0, No error) (Failed to connect to 192.168.1.250 port 49152: No route to host)
Nov 26, 2019 19:57:14.712 [0x7f355599a700] ERROR - SSDP: Error parsing device schema for http://192.168.1.250:49152/wps_device.xml
One problem, there is no device on 192.168.1.250 according to my network router, so what is Plex attempting to do here?
Ignore these.
Your router told Plex about a network device and Plex is asking if it is a media device. If you have a wireless satellite/extender/powerline adapter these sometime get addresses that may or may not show up in the router.
Hmm. Other than my network extender router (which I know the IP of and can log into). I’m not sure what this could be, nor can I ping it.
I’m getting the same messages. I’ve never had any device in my network that uses class C network:
Log:
Dec 28, 2019 23:18:46.414 [0xb0e97460] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.250:49152/description.xml
Dec 28, 2019 23:18:46.414 [0xb0e97460] DEBUG - HTTP requesting GET http://192.168.1.250:49152/description.xml
Network Traffic:
23:18:46.415274 IP 10.0.0.97.43840 > 192.168.1.250.49152: Flags [S], seq 1361329722, win 14600, options [mss 1460,nop,nop,sackOK,nop,wscale 9], length 0
23:18:47.408414 IP 10.0.0.97.43840 > 192.168.1.250.49152: Flags [S], seq 1361329722, win 14600, options [mss 1460,nop,nop,sackOK,nop,wscale 9], length 0
23:18:49.408417 IP 10.0.0.97.43840 > 192.168.1.250.49152: Flags [S], seq 1361329722, win 14600, options [mss 1460,nop,nop,sackOK,nop,wscale 9], length 0
You can see that is my Plex Server that is trying to connect to this inexistent IP. I looked up for this IP in Plex files using grep, but I didn’t find anything. I believe this configuation is hardcoded in Plex binaries.
Very annoying!
Something is advertising it.
Both network segments are non-routed private LAN.
Hello, I found the solution. Disable wps on your router or extender.
