QNAP TS453D Firmware QTS 5.2.3.3006
Plex Media server: V1.41.3
Before QNAP update everything was working correctly.
After firmware update, Plex is not auto scanning the library. It works only manually.
Any help?
can you please do the following?
- Make sure server DEBUG logging is abled (save if you make changes)
- Restart PMS
- Wait 3 minutes
- Download the server logs
- Attach the ZIP file
Hi, I have managed to Debug logging. I attach the server logs after debugging. Plex is not scanning automatically the files in my library.
Plex Media Server Logs_2025-01-30_16-59-41.zip (2.5 MB)
Paolo,
Are you certain this option is enabled ?
Please look at your settings,
UNCHECK the boxes – then SAVE
Now CHECK the boxes – and SAVE again.
Let’s see if that fixes it.
Hi, thanks. Yes I am certain that the boxes are checked. I followed your instructions and tried again to see if scan starts automatically. Unfortunately it does not, but manually it works.
