Plex Automatic Import and .plexignore
Server Version#: 1.6.3.1009-57cf57c8
When Scan my library automatically is checked plex doesn’t respect .plexignore.
My specific situation:
Sonarr grabs, downloads and dumps everything in to /Download. Once the download is complete Sonarr will rename and hardlink the episode in to the correct series/season location.
Plex “senses” the file system change and add the correct episode as expected while ALSO adding the /Downloads file to some weird show called Tower Prep for whatever reason.
Upon the normal hourly scan Plex will remove the unwanted show.
Don’t include your Downloads folder into your Plex library. Only point it to the folder where you are placing your hard links.
Right, right… I get ya, but on the flip side of that coin, Plex could honor .plexignore when doing automatic updates.
And I totally get that it likely never will, which is why I simply turned that back off rather than reconfigure my whole setup.
Keep in mind that if you enable the setting to detect changes, it detects the change within a folder only, if you place the .plexignore file, outside of that folder, the scanner doesn’t know it’s there. I haven’t tried, but what if you place another .plexignore file within the downloads folder to ignore everything in there.
My Folder Structure:
\ [various TV shows] (seasons below here)
\ Downloads (folder}
\ .plexignore (file)
\ [accidentally misfiled Top Gear special].mkv (file)
So did that work to use .plexignore within the folder itself?
I missed your idea about adding a specific .plexignore for the entire downloads folder. This worked. I wasn’t sure how to do the wildcards, but if anyone’s curious I used:
It’s a tiny text file and I do, in fact, want it to ignore absolutely everything so, I used everything.
I’ve marked your previous reply as the solution.
I will note that it frequently will add a downloaded episode from downloads temporarily. Sometimes it will be called Downloads and sometimes Tower Prep, but it will disappear shortly after. I guess sometimes my server is slower than others and I just happen to glance over and see it pop in or out.
For whatever reason it is now working considerably less well. I guess I’m going to go back to periodic scans rather than folder monitoring.
