Plex blocked my IP address
I have my own media server with a static IP, I connect to it from different places via TV or a browser and watch videos. but today I couldn’t log into the Plex app on TV, it became clear through experience that it was my static IP address that was blocked from connecting to the Plex servers, where should I write to figure this out and unblock it?
are you using a hosting service?
No, i use my home synology nas server
Then can you post your logs? I am not aware of Plex blocking home IP addresses.
log of what? The application on the TV (plex application on Samsung tizen) cannot connect to plex if I have a specific IP address. if I use a different IP then everything is fine
Stop Plex in package center.
Open File Station
Navigate PlexMediaServer / AppData / Plex Media Server
Right-click “Logs” → “Compress to Logs.zip”
Download the zip from the Syno then attach here.
Hello. You misunderstood me. At the moment it’s not important if i have a video server.
When you launch the plex client on the TV, it knocks on the plex.tv website. I saw this in the logs from my router. and without receiving a response, the application writes that there is no response. The application immediately does not work even at the stage of authorization on the plex website
This is why I presumed you had a server.
I am asking this because I can see that your DS718+ is signed into Plex.tv
I was going to use the server’s logs to confirm network connectivity from your modem/router → Plex.tv
– If you have a server and the server can sign in THEN we have a LAN problem.
– If neither the server nor player app can sign in THEN we have a different problem.
Since your server was last pinged to Plex.tv as of 1 hour ago, you aren’t blocked.
Can you please access the player’s logs and attach them?
https://support.plex.tv/articles/?s=player+logs&search=support_articles
as I wrote above, now the problem is not that my home video server cannot work correctly, but the problem is something else.
let’s do it again
I have a Samsung TV with the Tizen OS operating system.
The application is installed through the Samsung store.
When you launch this application for the first time (and the next time too), it tries to connect to the addresses *.plex.tv…
During normal operation, at the next stage, a QR code appears for authorization in your PLEX account (similar to authorizing YouTube on a TV.)
in my case, if I have a static IP 217.25.238.241, then the application writes that there is no access to the Internet and cannot log in. If I turn off the static IP and use any other one, everything works fine.
I spoke with the technical support of my Internet provider and they replied that your IP address was probably blacklisted by the Plex developers.
Using your current DHCP IP and the Static IP, I’ve now reached out to our operations team.
I’ll have an answer shortly.
Ok, thank you
@Andreykng
There is no block anywhere in Plex.tv for the 217.25.238.241 IP address.
When you switch to static and run mtr plex.tv (or traceroute) from your computer , how far does it trace ?
ip 100.127.112.158
traceroute to plex.tv (54.229.47.178), 30 hops max, 60 byte packets
1 100.127.0.1 (100.127.0.1) 1.063 ms 1.051 ms 1.023 ms
2 bras910.msk.corbina.net (78.107.181.106) 1.038 ms 0.978 ms 0.965 ms
3 81.211.5.96 (81.211.5.96) 1.884 ms 1.823 ms 81.211.5.98 (81.211.5.98) 1.812 ms
4 mx01.Stockholm.gldn.net (79.104.225.38) 27.600 ms 27.591 ms mx01.Stockholm.gldn.net (79.104.225.6) 27.474 ms
5 99.82.183.222 (99.82.183.222) 27.652 ms 27.602 ms 27.613 ms
6 52.93.144.88 (52.93.144.88) 34.216 ms 52.93.144.72 (52.93.144.72) 27.596 ms 52.93.144.24 (52.93.144.24) 32.384 ms
7 52.93.144.67 (52.93.144.67) 27.491 ms 52.93.144.35 (52.93.144.35) 27.805 ms 52.93.144.99 (52.93.144.99) 27.809 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
IP 217.25.238.241
1 lo-fras20.vrn.ru (195.98.64.208) 1.069 ms 0.999 ms 0.982 ms
2 a96-2-vl-58.vrn.ru (195.98.65.193) 2.342 ms 2.392 ms 2.303 ms
3 a96-vl-2-drl.vrn.ru (195.98.94.238) 2.335 ms 2.301 ms 2.290 ms
4 mskix.amazon.com (195.208.208.225) 28.914 ms 28.904 ms 28.891 ms
5 52.93.81.206 (52.93.81.206) 29.207 ms 52.93.81.222 (52.93.81.222) 27.043 ms 24.667 ms
6 52.93.81.49 (52.93.81.49) 28.467 ms 52.93.81.125 (52.93.81.125) 29.268 ms 52.93.81.141 (52.93.81.141) 28.146 ms
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Thank you.
I’ve confirmed we’re not blocking.
Since the addresses you show are Amazon
(We use Amazon AWS) we’re trying to track down if this is at the Amazon level
I got more information from the team.
They would like you to run mtr or WinMTR (windows mtr) to plex.tv.
Traceroute is ICMP versus MTR which is tcp.
We’ll have a more definitive answer
that’s what you asked for
here are adresses tv
tcp 192.168.1.195:35962 52.28.246.23:443 CLOSE
tcp 192.168.1.195:57711 3.74.104.170:443 CLOSE
tcp 192.168.1.195:33922 209.85.233.198:443 ESTABLISHED
tcp 192.168.1.195:48252 35.76.63.19:5223 ESTABLISHED
tcp 192.168.1.195:41597 185.199.110.153:443 ESTABLISHED
tcp 192.168.1.195:54546 108.156.15.235:443 ESTABLISHED
tcp 192.168.1.195:40056 52.30.182.95:443 ESTABLISHED
tcp 192.168.1.195:49802 173.194.222.101:443 ESTABLISHED
tcp 192.168.1.195:44097 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:57021 3.219.173.44:443 SYN_SENT
tcp 192.168.1.195:44095 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44104 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44103 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:60359 3.232.230.6:443 SYN_SENT
tcp 192.168.1.195:44096 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44113 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44110 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44111 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:60832 18.158.169.100:443 TIME_WAIT
tcp 192.168.1.195:57123 64.95.100.54:443 TIME_WAIT
tcp 192.168.1.195:56992 139.45.219.42:80 TIME_WAIT
tcp 192.168.1.195:44367 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:44370 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:57081 64.95.100.54:443 TIME_WAIT
tcp 192.168.1.195:44366 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:49817 54.77.94.192:443 TIME_WAIT
tcp 192.168.1.195:58592 72.251.241.207:443 TIME_WAIT
tcp 192.168.1.195:55280 18.165.142.141:443 TIME_WAIT
tcp 192.168.1.195:44373 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:44378 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:44374 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:48864 20.67.97.247:443 TIME_WAIT
tcp 192.168.1.195:35988 157.55.194.109:443 TIME_WAIT
tcp 192.168.1.195:46452 20.67.97.247:80 TIME_WAIT
tcp 192.168.1.195:56985 139.45.219.42:80 TIME_WAIT
tcp 192.168.1.195:36792 139.45.219.9:80 TIME_WAIT
tcp 192.168.1.195:44639 40.118.14.214:443 TIME_WAIT
tcp 192.168.1.195:50708 18.165.142.48:443 TIME_WAIT
tcp 192.168.1.195:50172 35.158.61.188:443 TIME_WAIT
tcp 192.168.1.195:56929 139.45.219.42:80 TIME_WAIT
tcp 192.168.1.195:60432 18.165.140.101:80 TIME_WAIT
tcp 192.168.1.195:53206 35.157.24.228:443 TIME_WAIT
tcp 192.168.1.195:44379 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:35991 157.55.194.109:443 TIME_WAIT
tcp 192.168.1.195:44372 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:51068 18.192.73.152:443 TIME_WAIT
tcp 192.168.1.195:54240 104.85.249.112:80 TIME_WAIT
tcp 192.168.1.195:55017 52.214.188.173:443 TIME_WAIT
tcp 192.168.1.195:44377 157.55.184.57:443 TIME_WAIT
tcp 192.168.1.195:40915 18.165.142.196:443 TIME_WAIT
tcp 192.168.1.195:57119 64.95.100.54:443 TIME_WAIT
tcp 192.168.1.195:57120 64.95.100.54:443 TIME_WAIT
tcp 192.168.1.195:49825 54.77.94.192:443 TIME_WAIT
tcp 192.168.1.195:58585 72.251.241.207:443 TIME_WAIT
tcp 192.168.1.195:55274 18.165.142.141:443 TIME_WAIT
tcp 192.168.1.195:60436 18.165.140.101:80 TIME_WAIT
tcp 192.168.1.195:53612 95.100.111.240:80 TIME_WAIT
tcp 195.201.164.88:55886 192.168.1.97:18080 TIME_WAIT
tcp 192.168.1.195:34118 18.165.140.109:80 TIME_WAIT
tcp 192.168.1.195:40930 18.165.142.196:443 TIME_WAIT
tcp 192.168.1.195:40914 18.165.142.196:443 TIME_WAIT
udp 192.168.1.195:57758 195.98.64.65:53 ASSURED
udp 192.168.1.195:37290 195.98.64.65:53 ASSURED
udp 192.168.1.195:32770 195.98.64.65:53 ASSURED
udp 192.168.1.195:57664 195.98.64.65:53 ASSURED
udp 192.168.1.195:53515 195.98.64.65:53 ASSURED
udp 192.168.1.195:59008 195.98.64.65:53 ASSURED
udp 192.168.1.195:43138 195.98.64.65:53 ASSURED
udp 192.168.1.195:50215 195.98.64.65:53 ASSURED
udp 192.168.1.195:57256 195.98.64.65:53 ASSURED
udp 192.168.1.195:41925 195.98.64.65:53 ASSURED
udp 192.168.1.195:46569 195.98.64.65:53 ASSURED
udp 192.168.1.195:37712 195.98.64.65:53 ASSURED
udp 192.168.1.195:48730 195.98.64.65:53 ASSURED
udp 192.168.1.195:44074 195.98.64.65:53 ASSURED
udp 192.168.1.195:51849 195.98.64.65:53 ASSURED
udp 192.168.1.195:53199 195.98.64.65:53 ASSURED
udp 192.168.1.195:58300 195.98.64.65:53 ASSURED
udp 192.168.1.195:51536 195.98.64.65:53 ASSURED
udp 192.168.1.195:48361 195.98.64.65:53 ASSURED
udp 192.168.1.195:52512 195.98.64.65:53 ASSURED
udp 192.168.1.195:42232 195.98.64.65:53 ASSURED
udp 192.168.1.195:54054 195.98.64.65:53 ASSURED
udp 192.168.1.195:57042 195.98.64.65:53 ASSURED
udp 192.168.1.195:60979 195.98.64.65:53 ASSURED
udp 192.168.1.195:60640 195.98.64.65:53 ASSURED
udp 192.168.1.195:60766 195.98.64.65:53 ASSURED
udp 192.168.1.195:56603 195.98.64.65:53 ASSURED
udp 192.168.1.195:40521 195.98.64.65:53 ASSURED
udp 192.168.1.195:47000 195.98.64.65:53 ASSURED
udp 192.168.1.195:51793 195.98.64.65:53 ASSURED
udp 192.168.1.195:44298 195.98.64.65:53 ASSURED
udp 192.168.1.195:57832 195.98.64.65:53 ASSURED
udp 192.168.1.195:60917 195.98.64.65:53 ASSURED
udp 192.168.1.195:37556 195.98.64.65:53 ASSURED
udp 192.168.1.195:36847 195.98.64.65:53 ASSURED
udp 192.168.1.195:33314 195.98.64.65:53 ASSURED
udp 192.168.1.195:57209 195.98.64.65:53 ASSURED
udp 192.168.1.195:36168 195.98.64.65:53 ASSURED
udp 192.168.1.195:41375 195.98.64.65:53 ASSURED
udp 192.168.1.195:38645 195.98.64.65:53 ASSURED
udp 192.168.1.195:47228 195.98.64.65:53 ASSURED
udp 192.168.1.195:39556 195.98.64.65:53 ASSURED
udp 192.168.1.195:56694 195.98.64.65:53 ASSURED
udp 192.168.1.195:58518 195.98.64.65:53 ASSURED
udp 192.168.1.195:50791 195.98.64.65:53 ASSURED
udp 192.168.1.195:34216 195.98.64.65:53 ASSURED
udp 192.168.1.195:36381 195.98.64.65:53 ASSURED
udp 192.168.1.195:43788 195.98.64.65:53 ASSURED
udp 192.168.1.195:40301 195.98.64.65:53 ASSURED
udp 192.168.1.195:33643 195.98.64.65:53 ASSURED
udp 192.168.1.195:44398 195.98.64.65:53 ASSURED
udp 192.168.1.195:39534 195.98.64.65:53 ASSURED
udp 192.168.1.195:44464 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:33080 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:45189 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:40865 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:33440 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:53540 195.98.64.65:53 UNREPLIED
this is what happens when I have a static IP
start plex
tcp 192.168.1.195:58503 63.32.129.144:443 ESTABLISHED
tcp 192.168.1.195:58230 185.199.111.153:443 ESTABLISHED
tcp 192.168.1.195:44132 173.194.222.100:443 FIN_WAIT
tcp 192.168.1.195:44181 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44168 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44174 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44177 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44171 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44176 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44166 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44178 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44188 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44170 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44167 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44187 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44173 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44169 192.229.221.95:80 SYN_SENT
tcp 192.168.1.55:12195 34.219.80.72:443 TIME_WAIT
tcp 192.168.1.195:57544 64.95.100.60:443 TIME_WAIT
tcp 192.168.1.195:36938 139.45.219.9:80 TIME_WAIT
tcp 192.168.1.195:50835 18.165.142.48:443 TIME_WAIT
udp 192.168.1.195:49564 195.98.64.65:53 ASSURED
udp 192.168.1.195:40468 195.98.64.65:53 ASSURED
udp 192.168.1.195:34267 195.98.64.65:53 ASSURED
udp 192.168.1.195:60172 195.98.64.65:53 ASSURED
udp 192.168.1.195:33987 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:56769 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:52296 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:49255 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:38656 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:57103 195.98.64.65:53 UNREPLIED
sing in
tcp 192.168.1.195:44132 173.194.222.100:443 ASSURED
tcp 192.168.1.195:58230 185.199.111.153:443 CLOSE
tcp 192.168.1.195:48933 35.186.247.156:443 ESTABLISHED
tcp 192.168.1.195:44192 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44193 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44190 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44189 192.229.221.95:80 SYN_SENT
udp 192.168.1.195:55485 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:48621 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:39516 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:55842 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:49070 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:54045 195.98.64.65:53 UNREPLIED
unable to reeach plex
tcp 192.168.1.195:55628 52.16.114.76:443 CLOSE
tcp 192.168.1.195:55630 52.16.114.76:443 CLOSE
tcp 192.168.1.195:44802 104.81.117.163:80 ESTABLISHED
tcp 192.168.1.195:44901 34.120.214.181:443 ESTABLISHED
tcp 192.168.1.195:38586 139.45.219.11:80 ESTABLISHED
tcp 192.168.1.195:55633 52.16.114.76:443 ESTABLISHED
tcp 192.168.1.195:44202 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44203 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44197 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44200 192.229.221.95:80 SYN_SENT
tcp 192.168.1.195:44198 192.229.221.95:80 SYN_SENT
udp 192.168.1.195:59641 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:58164 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:36011 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:53044 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:37074 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:60309 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:54655 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:50523 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:56078 195.98.64.65:53 UNREPLIED
next time
my ip 95.25.206.108
plex work!
Proto NATed Address Destination Address State
tcp 192.168.1.195:48441 35.76.63.19:5223 ESTABLISHED
tcp 192.168.1.195:56339 74.125.131.190:443 ESTABLISHED
tcp 192.168.1.195:44237 192.229.221.95:80 ESTABLISHED
tcp 192.168.1.195:55665 52.16.114.76:443 ESTABLISHED
tcp 192.168.1.195:40865 10.0.0.1:443 SYN_SENT
tcp 192.168.1.97:57195 41.141.162.7:5463 SYN_SENT
tcp 192.168.1.97:41951 95.79.16.169:23457 SYN_SENT
tcp 192.168.1.195:40864 10.0.0.1:443 SYN_SENT
udp 192.168.1.195:36309 195.98.64.65:53 ASSURED
udp 192.168.1.195:37897 8.8.8.8:53 ASSURED
udp 192.168.1.195:50049 195.98.64.65:53 ASSURED
udp 192.168.1.195:36742 8.8.8.8:53 ASSURED
udp 192.168.1.195:46752 195.98.64.65:53 UNREPLIED
udp 192.168.1.195:50184 8.8.8.8:53 UNREPLIED
udp 192.168.1.195:48268 8.8.8.8:53 UNREPLIED
udp 192.168.1.195:50955 195.98.64.65:53 UNREPLIED
