Not sure if youview should be freeview but problem is that here in Wales UK there is no 104 Channel 4 HD to be selected in the guide list, when setting up channels. There is a 07 C4 (C4HD) but this is used for 07 SD channel 4. There is 103 ITV1HDL and 105 CH5HD but 104 is missing.
No Channel 4 HD 104.
Try mapping 053, you are in the same area as me.
053 seems to be CH4HD although it doesn’t match to the document I attached, but then it’s not youview, so it probably shouldn’t.
Yeah tried that and works thanks. Why this is at 53 and not 104 not sure.
This is a bit of a pain… :neutral: Resetting up the DVR now to see if C4 HD shows up for me.
Is youview still the only guide for us Welsh to pick, or has freeview finally appeared?
And it works! I notice that sometimes I need to run the DVR setup twice though… all the channels don’t always come through correctly.
