Hi There,
I’m running latest plex 1.9.7.4460-a39b25852 on Debian Jessie 8.9 on a bare mettle PC (not in docker) yes I use weird IP’s.
When scanning for my HDHomerun nothing is located. When manually entering the IP of the HDHR I get an error. “There was a problem adding the device”
I see errors in the logs when attempting to manually add the device. Log’s are attached.
Running ‘hdhomerun_config discover’ from CLI finds device ok from the host running Plex.
Other devices can watch TV fine.
Appears to be a Plex issue from what I can tell.
HDHomerun Info:
Model: HDHR4-2DT
Firmware: 20170930
Thanks for your help.
