Plex can't handle non-English character in folder path when adding folder to library
For example, I have a folder path:
/Video/电影/Kids
When I try to add the folder Kids to a library, I need to click Video folder, then click 电影 folder, then I can click Kids folder to select and add it to a library.
However, when I click on 电影 folder, it takes me back to the root folder / instead of showing me Kids subfolder.
Sever version 1.30.2.6563. Tested in on Synology (installed as package), and OpenMediaVault (installed as docker container).
The console output when I click on that folder, the folder name is empty:
[Req#2b099] DirectoryBrowser: Decoded [L3ZvbHVtZTEvRnVsaS@nlLXlvbE=] to []
When I click on a folder that starts with English character:
[Req#2b0d5] DirectoryBrowser: Decoded [L3ZvbHVtZTEvVmlkZW8=] to [/volume1/Video]
What’s odd is that it can handle non-English char in the path, as long as as the folder doesn’t start with a non-English character, for example, this is fine:
[Req#2b0fa] DirectoryBrowser: Decoded [L3ZvbHVtZTEvRnVsaS96eWzop4bpopE=] to [/volume1/Fuli/zyl视频]
