hello all, new here, couldn't find the suggestion box, so here goes:
Devs, please add MKV support to Plex on Synology.
it's just a wrapper for other formats, this one file i tried to play, i believe is MP4 inside a MKV, it should read fine but all i get in plex is some generic error message with a sad face. :( a lil more info how to fix this error would help too, like installing VLC (which is already on this laptop). And yes this file plays in VLC.
General
Format : Matroska
Format version : Version 4 / Version 2
File size : 711 MiB
Duration : 22mn 8s
Overall bit rate : 4 491 Kbps
Encoded date : UTC 2013-04-08 08:48:23
Writing application : mkvmerge v6.1.0 ('Old Devil') built on Mar 2 2013 14:32:37
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 22mn 8s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : H.264
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 22mn 8s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 60.8 MiB (9%)
Title : DD5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 22mn 8s
Channel(s) : 2 channels
Channel positions : Front: L R
Title : AAC2.0
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : CC
Language : English
Default : No
Forced : No
thanks for reading
