See the show start to record and then fail within about 4 seconds.
Jun 30, 2017 09:00:00.300 [14175] DEBUG - DVR:Subscription: Resolved subscription to library item ‘Let’s Make A Deal’ (473)
Jun 30, 2017 09:00:00.305 [14175] DEBUG - There were 1 top-level paths for Let’s Make A Deal.
Jun 30, 2017 09:00:00.342 [14175] DEBUG - DVR:Grabber: Saving recording to /storage/F25F-9619/NVIDIA_SHIELD/TV Shows/.grab/c11626a57357543a6080ab1dfcce0837b81960d3
Jun 30, 2017 09:00:00.403 [14175] DEBUG - DVR:Grabber: Going to record for 3600 seconds, final URL is http://192.168.2.106:5004/auto/v2.1?transcode=heavy
Jun 30, 2017 09:00:00.424 [14175] DEBUG - DVR:Grabber: Setting timer to stop grab of ‘Let’s Make a Deal - E32 - Episode 32’ in 3600 seconds.
Jun 30, 2017 09:00:00.424 [14175] DEBUG - DVR:Segmenter: Creating a new recorder for http://192.168.2.106:5004/auto/v2.1?transcode=heavy.
Jun 30, 2017 09:00:00.435 [14175] DEBUG - DVR:Grabber: Waiting for a tuner (2 available).
Jun 30, 2017 09:00:00.435 [14175] DEBUG - DVR:Grabber: Allocated a tuner (1 left)
Jun 30, 2017 09:00:00.473 [14175] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Jun 30, 2017 09:00:00.473 [14175] DEBUG - Selecting best audio stream for part ID -1 (autoselect: 0 language: en)
Jun 30, 2017 09:00:00.474 [14175] DEBUG - Falling back to picking the first audio stream 1.
Jun 30, 2017 09:00:00.474 [14175] DEBUG - Audio Stream: -1, Subtitle Stream: -1
Jun 30, 2017 09:00:00.474 [14175] ERROR - Unable to find title for item of type 5
Jun 30, 2017 09:00:00.475 [14175] DEBUG - MDE: analyzing media item -1
Jun 30, 2017 09:00:00.475 [14175] DEBUG - MDE: : no direct play video profile exists for http/mpegts/
Jun 30, 2017 09:00:00.475 [14175] DEBUG - MDE: : no direct play video profile exists for http/mpegts//
Jun 30, 2017 09:00:00.475 [14175] DEBUG - MDE: : codec is unavailable for analysis
Jun 30, 2017 09:00:00.502 [14175] ERROR - Unable to find title for item of type 5
Jun 30, 2017 09:00:00.502 [14175] DEBUG - MDE: : selected media 0 / -1
Jun 30, 2017 09:00:00.502 [14175] DEBUG - Cleaning directory for session 7f32bff8-277a-4a2b-aac4-159805a46627 ()
Jun 30, 2017 09:00:00.503 [14175] DEBUG - Starting a transcode session 7f32bff8-277a-4a2b-aac4-159805a46627 at offset -1.0 (state=3)
Jun 30, 2017 09:00:00.503 [14175] DEBUG - Streaming Resource: Added session 0x201e46b960:7f32bff8-277a-4a2b-aac4-159805a46627
Jun 30, 2017 09:00:00.509 [14175] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Jun 30, 2017 09:00:00.509 [14175] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Jun 30, 2017 09:00:00.515 [14175] DEBUG - Job running: EAE_ROOT=’/data/user/0/com.plexapp.mediaserver.smb/tmp/pms-3ac736f2-043d-46d2-a329-cffdacb854ef/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/data/user/0/com.plexapp.mediaserver.smb/Plex\ Media\ Server/Codecs/18f9bcf-1233-android-aarch64/’ XDG_CACHE_HOME=’/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/’ XDG_DATA_HOME=’/data/user/0/com.plexapp.mediaserver.smb/Resources/’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder’ ‘-noaccurate_seek’ ‘-ignore_unknown’ ‘-scan_all_pmts’ ‘-1’ ‘-i’ ‘http://192.168.2.106:5004/auto/v2.1?transcode=heavy’ ‘-map’ ‘0:V?’ ‘-codec:V’ ‘copy’ ‘-map’ ‘0:a?’ ‘-codec:a’ ‘copy’ ‘-copypriorss:a’ ‘0’ ‘-map’ ‘0:s?’ ‘-codec:s’ ‘copy’ ‘-segment_format’ ‘mpegts’ ‘-f’ ‘ssegment’ ‘-individual_header_trailer’ ‘0’ ‘-segment_time’ ‘1’ ‘-segment_start_number’ ‘0’ ‘-segment_copyts’ ‘1’ ‘-segment_time_delta’ ‘0.0625’ ‘-segment_list’ ‘http://127.0.0.1:32400/video/:/transcode/session/7f32bff8-277a-4a2b-aac4-159805a46627/151eaaa3-f687-4bfc-96ac-687d6bf1a656/seglist’ ‘-segment_list_type’ ‘csv’ ‘-segment_list_size’ ‘2147483647’ ‘-max_delay’ ‘5000000’ ‘-avoid_negative_ts’ ‘disabled’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘media-%05d.ts’ ‘-start_at_zero’ ‘-copyts’ ‘-vsync’ ‘cfr’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/7f32bff8-277a-4a2b-aac4-159805a46627/151eaaa3-f687-4bfc-96ac-687d6bf1a656/progress’
Jun 30, 2017 09:00:04.387 [14175] DEBUG - Using default transcode duration of 120 minutes
Jun 30, 2017 09:00:04.387 [14175] DEBUG - Started session successfully: 7f32bff8-277a-4a2b-aac4-159805a46627
Jun 30, 2017 09:00:04.388 [14175] DEBUG - DVR:Recorder: It took 3.9 sec to start the session for http://192.168.2.106:5004/auto/v2.1?transcode=heavy
Jun 30, 2017 09:00:04.389 [14175] ERROR - Unable to find title for item of type 5
Jun 30, 2017 09:00:04.389 [14175] DEBUG - MDE: analyzing media item -1
Jun 30, 2017 09:00:04.389 [14175] ERROR - MDE: video has neither a video stream nor an audio stream
Jun 30, 2017 09:00:04.389 [14175] DEBUG - MDE: ignoring media item -1
Jun 30, 2017 09:00:04.389 [14175] ERROR - MDE: no compatible media decisions are available
Jun 30, 2017 09:00:04.389 [14175] ERROR - DVR:Recorder: Unable to compute media decision.
Jun 30, 2017 09:00:04.389 [14175] ERROR - DVR:Recorder: Error 14 starting the record, shutting things down.
Jun 30, 2017 09:00:04.389 [14175] DEBUG - DVR:Recorder: Asked to stop recording ‘Let’s Make a Deal - E32 - Episode 32’.
Jun 30, 2017 09:00:04.389 [14175] DEBUG - DVR:Recorder: Stopping transcode session.
Jun 30, 2017 09:00:04.389 [14175] DEBUG - Killing job.
Jun 30, 2017 09:00:04.390 [14175] DEBUG - Signalling job ID 14647 with 9
Jun 30, 2017 09:00:04.390 [14175] DEBUG - Job was already killed, not killing again.
Jun 30, 2017 09:00:04.390 [14175] DEBUG - Stopping transcode session 7f32bff8-277a-4a2b-aac4-159805a46627
Jun 30, 2017 09:00:04.390 [14175] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
Jun 30, 2017 09:00:04.390 [14175] DEBUG - DVR:Grabber: Operation for Let’s Make a Deal - E32 - Episode 32 completed with status error (An unknown error occurred)
Jun 30, 2017 09:00:04.390 [14175] DEBUG - Activity: Ended activity 2f1a99a2-07f7-4ca1-9777-7a27d0204679.
Jun 30, 2017 09:00:04.399 [14175] ERROR - DVR:Grabber: Starting media grab failed.
I do see this line where it starts the recording and shows the URL Plex uses to grab the recording from your HDHR:
I am assuming you have an Extend with the transcode settings set in Plex. Have you tried recording with the Transcode set to Original Quality? I think that is the setting for no transcoding, don’t have an Extend myself. Just curious if you can recording something without the transcode in Plex. The extend has some internal settings you can use without setting transcoding in Plex I thought.
