I renamed VideoA in Videos as you told me, and on PMS I find Videos normally.
In fact, PMS worked normally for several months, and the addition “blank1” happened twice, the last one last week
Other instructions on how to check for and remove a “ghost drive” can be found here if that is what the issue is. ( does require being comfortable with terminal )
I see that it is quite complicated, moreover I do not master English very well, it may be necessary to reformat my hard drives (after making a backup)
When your mapping the path in plex for each drive, are there folders in the path for videoA drive and videob drive with the same name?
There’s some kind of duplication happening here that’s causing it.
No, there is not the same name
Just like you pasted this screenshot-
Please do it again, only this time click on the videoa drive in in the screenshot. Do it again for the videob drive, click on it and paste the screen here.
