drensin
February 19, 2011, 6:39pm
101
I have an error "Transcoder Failure" error with Windows PMS on Windows 7.
None of my files can play although they play fine with the Android client.
you have todays update and are leaving the username/password empty?
cde2006
February 19, 2011, 6:45pm
102
Yes username and password are empty and i downloaded the latest version.
drensin
February 19, 2011, 6:46pm
103
ok... I'll install the Windows PMS later and see what's up.
-dave
luk
February 19, 2011, 9:21pm
104
Hi dave, first thanks for this client!
But I also get the “transcoder failure” message if I want to start any tv show or movie…I´ve installed the Plex Media Manager on my Win7 Desktop and this Plex Client on my HTPC (Win7).
drensin
February 19, 2011, 10:20pm
105
Hi dave, first thanks for this client! :)
But I also get the "transcoder failure" message if I want to start any tv show or movie...I´ve installed the Plex Media Manager on my Win7 Desktop and this Plex Client on my HTPC (Win7).
Fixed! Get it [HERE](http://plex-win32-client.googlecode.com/files/Release.RC.1.1.zip)
-dave
drensin
February 19, 2011, 10:47pm
106
ANNOUNCING RC1.2
Now compatible with Plex Media Server for Windows.
get it HERE
-dave
Thanks for the hard work Dave. Keep it up! btw is there settings for the transcoder aka if I was locally at home and there doesn’t need to be transcoding vs a laptop on the road. and can you manually set bitrates yourself like air video can?
drensin
February 20, 2011, 4:14pm
108
Thanks for the hard work Dave. Keep it up! :) btw is there settings for the transcoder aka if I was locally at home and there doesn't need to be transcoding vs a laptop on the road. and can you manually set bitrates yourself like air video can?
working on exactly that this week..
-dave :-)
cde2006
February 20, 2011, 4:36pm
109
Got this error, and the playback window doesn’t always open full screen. I am on a 30" monitor in 2560x1600
See the end of this message for details on invoking <br />
just-in-time (JIT) debugging instead of this dialog box.<br />
<br />
************** Exception Text **************<br />
System.IO.IOException: The process cannot access the file 'C:\Users\Administrator\AppData\Local\media.ts' because it is being used by another process.<br />
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)<br />
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)<br />
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)<br />
at Plex.Client.Win32.Form1.PlayTranscodedWithSegments(String part, Int32 bufferBlocks, Int32 quality)<br />
at Plex.Client.Win32.Form1.PlayStream(String url, Int32 offset)<br />
at Plex.Client.Win32.Form1.listView1_ItemActivate(Object sender, EventArgs e)<br />
at System.Windows.Forms.ListView.OnItemActivate(EventArgs e)<br />
at System.Windows.Forms.ListView.WmReflectNotify(Message& m)<br />
at System.Windows.Forms.ListView.WndProc(Message& m)<br />
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)<br />
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)<br />
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)<br />
<br />
<br />
************** Loaded Assemblies **************<br />
mscorlib<br />
Assembly Version: 2.0.0.0<br />
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)<br />
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll<br />
----------------------------------------<br />
Plex.Client.Win32<br />
Assembly Version: 1.0.0.0<br />
Win32 Version: 1.0.0.0<br />
CodeBase: file:///C:/Users/Administrator/Desktop/Plex%20CLient/Plex.Client.Win32.exe<br />
System.Windows.Forms<br />
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)<br />
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll<br />
System<br />
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll<br />
System.Drawing<br />
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll<br />
System.Core<br />
Assembly Version: 3.5.0.0<br />
Win32 Version: 3.5.30729.4926 built by: NetFXw7<br />
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll<br />
System.Configuration<br />
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll<br />
System.Xml<br />
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll<br />
ZeroconfService<br />
Assembly Version: 0.6.0.0<br />
Win32 Version: 0.6.0.0<br />
CodeBase: file:///C:/Users/Administrator/Desktop/Plex%20CLient/ZeroconfService.DLL<br />
System.Web<br />
Win32 Version: 2.0.50727.4955 (win7RTMGDR.050727-4900)<br />
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll<br />
<br />
************** JIT Debugging **************<br />
To enable just-in-time (JIT) debugging, the .config file for this<br />
application or computer (machine.config) must have the<br />
jitDebugging value set in the system.windows.forms section.<br />
The application must also be compiled with debugging<br />
enabled.<br />
<br />
For example:<br />
<br />
<configuration><br />
<system.windows.forms jitDebugging="true" /><br />
</configuration><br />
<br />
When JIT debugging is enabled, any unhandled exception<br />
will be sent to the JIT debugger registered on the computer<br />
rather than be handled by this dialog box.
drensin
February 20, 2011, 4:41pm
110
how often have you gotten this error? are you switching between videos unusually fast?
-dave
Got this error, and the playback window doesn't always open full screen. I am on a 30" monitor in 2560x1600
<br />
<br />
<br />
mscorlib<br />
System<br />
System.Core<br />
System.Xml<br />
System.Web<br />
<br />
enabled.<br />
<br />
For example:<br />
<br />
<br />
cde2006
February 20, 2011, 4:49pm
111
-dave
It's a bit laggy here, my folder got 300+ video. So I clicked a few time before I got a response.
Also the video seems to be sized a 640x480 and change the desktop resolution it seems.
cde2006
February 20, 2011, 4:58pm
112
Even I use a small folder I got the error on playing the file a second time.
First play most of the time doesn't have this error, but I still cannot play the output video window doesn't seem to be open at my resolution. The desktop switch temporarily to 640x480 and that's about it. Even in windowed mode (F11) doesn't seems to help.
OrbMan
February 20, 2011, 10:43pm
113
I get the same error on Windows 7 32-bit running at 1280x800.
<br />
<br />
<br />
mscorlib<br />
System<br />
System.Core<br />
System.Xml<br />
System.Web<br />
<br />
enabled.<br />
<br />
For example:<br />
<br />
<br />
drensin
February 20, 2011, 11:40pm
114
Not sure what this is all about... Are you per chance running the client "As Administrator" ?
-dave
drensin
February 20, 2011, 11:41pm
115
RC 1.3
bug fixes…
get it HERE
ToDo: Trancoding quality options / Direct streaming
-dave
OrbMan
February 21, 2011, 12:41am
116
I am not…is that necessary?
-dave
drensin
February 21, 2011, 7:08am
117
I am not...is that necessary?
no, it's not. I just notice that the buffer file is trying to be created in the Administrator's temp dir. Just for a test, try running the client as administrator and tell me what you get, please.
-dave
Hi guys
Great job, thanks…
We only use Windows in my company, and my colleagues are suddenly very interrested… :rolleyes:
I installed your last RC on my laptop (Win7 32 bits) and tried to access my PMS at home…
I got a 407 error: Proxy authentication
Is it possible to enter Proxy information in the config files ?? (as specified in a previous post)
Cheers
PS: I also tried on an open network, and I got a 401: Authorization required… and I set the username/password in the config file ??? Where is my mistake ??? :blink:
OrbMan
February 21, 2011, 12:34pm
119
no, it’s not. I just notice that the buffer file is trying to be created in the Administrator’s temp dir. Just for a test, try running the client as administrator and tell me what you get, please.
-dave
That error trace was not mine, so I can't vouch for the details. But I did get the same error message. I am now out of town, so when I try to run the client over the internet, it just says buffering forever, I guess because the transcoding is not working yet? Not a firewall issue, as the Plex client on my iPhone is working fine. If I get any more errors I'll give you my trace.
drensin
February 21, 2011, 2:16pm
120
no... The transcoding should be working fine. Do you have security turned on your PMS? Did you enter your credentials at the Server Selector screen?
-dave
